Old 06-02-2014, 01:36 PM   #1
bgoodsoil OP
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,603
Maryland/NVA KTM shop?
Hello Marylanders!
I just moved to DC and I'm looking for some recommendations on a suspension shop. I'm putting one of the WP4860 forks from a KTM on my airhead BMW and I'm going to need some help with the valving. Anybody know a shop that might be willing to help with a project like that?
Also if you've got any trail recommendations I'll take those too!
Thanks,
Brad
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 06-02-2014, 06:58 PM   #2
anotherguy
anotherguy's Avatar
Oddometer: 6,631
Look here.Not close by but UPS goes there every day. Very reasonable prices. Give 'em a yell.
you don't see luggage racks on a hearse..........act accordingly
Old 06-02-2014, 07:04 PM   #3
windblown101
Oddometer: 913
+1 Good folks. I had them re-do the suspension on my KTM.
windblown101 is offline   Reply With Quote
Old 06-03-2014, 09:38 AM   #4
bgoodsoil OP
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,603
Looks like a neat shop. I'll give them a visit. Thanks!
Old 06-03-2014, 11:34 AM   #5
JaxObsessed
Rhonda be strong.
JaxObsessed's Avatar
Location: From Alabama to Newfoundland it's all Appalachian
Oddometer: 14,491
Who's the man? ^^^
Didn't know they were that close.
JaxObsessed is offline   Reply With Quote
Old 06-03-2014, 11:56 AM   #6
Dual Sport Armory
Dual Sport Armory's Avatar
Oddometer: 224
KTM suspension
We would be glad to help
Do lots and lots of KTM suspension.
as well most major brands
give us a call
540-504-7498
Allen
Adventure on!
Dual Sport Armory is offline   Reply With Quote
Old 06-03-2014, 12:04 PM   #7
bgoodsoil OP
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,603
Don't promise yourself just yet--this isn't going to be a cut & dry project.
I've got custom triples that have the huge 38mm offset used on the airheads. It has a Scott's stabilizer and a post for the frame. I'll be getting some forks off eBay unless you guys have some lying around. I've got a new wheel with the later 26mm axle and it's got a rotor on it. I still need a caliper and a master cylinder/lever.
Do you have a source for custom springs? I'll be shortening the forks down to the stock 8" for the my G/S. I've only got a vague idea of the stiffness that I'll need and I don't have a way to test sag until I pop them in and try it. I'm hoping to avoid the 'buy it and try it' approach at $150+ a shot.
I know I want the open chamber forks and from I've gathered they're still on the EXC/XC-W models. Is that right?
I read that in '09 there were some fork improvements to the MXMA PAs. Was it on all EXC/XC-W models? Is it worthwhile to wait around until some '09+ forks pop up?
http://www.motorcycle-usa.com/179/24...Bike-Test.aspx
On the outside, the chassis changes focus around the suspension. It is almost cliché to say that the KTM suspension is better this year, as it gets better every year. But the effects of the changes this year are huge! The fork tubes are now sourced from Japan and feature a thinner wall and improved chrome plating resulting in lower friction and improved flex.
Old 06-03-2014, 12:20 PM   #8
Dual Sport Armory
Oddometer: 224
they reduced the dampening rod dia on the 07/08's then changed the mid valve dia on later 09.
If you can find a clean set of 09 or newer they are a better fork
but that being said we've had good success setting up the open chambers from 03 and up, so if the price is right and they are clean go for it.
not a problem to lower and we do have a source that can custom make springs if need be.
when you get closer to getting your project ready, we would be happy to help, I have a spring generator that should be able to handle your bike,
lots and lots of factors to consider when your doing a project like your planning
Good luck and have fun with it
Old 06-03-2014, 12:50 PM   #9
bgoodsoil OP
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,603
That's an understatement. I've got an 11.5 gallon tank so there's a huge swing in weight from full to empty. Add to that weight changes from having a touring load+firewood to dropping the boxes entirely for offroading.
I thought I'd peg the sag for somewhere in the middle and adjust damping. Having on-the-fly adjustment is going to be huge.
Times are GMT -7.   It's 08:56 PM.
