Old 06-03-2014, 08:10 AM   #1
cjbiker OP
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,657
950 Adventure jetting/starting question
Hi, quick question on jetting for a 2005 950 Adventure. I just installed the Head2Wind prefilter and jet kit. 45 pilots, 70 IAJs, 145/148 mains. Needles on the 3rd clip. Stock exhaust, no canister to be found, sea-level elevation. I think I set the fuel screws at 2 turns (should have written it down!). Runs great except it is a bit hard to start cold. I have to crack the throttle a bit and it takes a few cycles of cranking for a few seconds. Once it warms up, it's perfect. No issues restarting when hot. Any suggestions? I'm thinking of turning the fuel screws in a half-turn, but since I have to disassemble half the bike to get to them, I'd like to have an educated guess before I do. Yes, I know I can get extended fuel screws for $100. I might go that route, but I'd rather not. Thanks!
cjbiker is online now   Reply With Quote
Old 06-03-2014, 08:21 AM   #2
AdvRonski
They call me......Ronski
Location: Wishing I was back in Grand Junction, now in MN
Oddometer: 695
Just to be clear, are you using the choke?
Ronski
Enduro Racer & Big Bike Adventurer
AdvRonski is offline   Reply With Quote
Old 06-03-2014, 08:29 AM   #3
cjbiker OP
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,657
Yes. I've tried full choke, half, quarter, etc. It needs full choke and the throttle cracked to start. 40-50 degree morning temps.
Old 06-03-2014, 11:08 AM   #4
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,445
Tight valves cause this symptom?
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 06-03-2014, 12:07 PM   #5
cjbiker OP
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,657
That usually results in hard starting when hot, as far as I've heard. And I should have said, it started fine with the stock jetting.
Old 06-03-2014, 05:46 PM   #6
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,250
I'd go back to stock jetting then.
Chuckracer is offline   Reply With Quote
Old 06-03-2014, 07:39 PM   #7
cjbiker OP
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,657
But then it would be too rich with the prefilter
Old 06-03-2014, 07:56 PM   #8
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,250
I'd choose good starting over a pre filter.
Old 06-04-2014, 06:05 AM   #9
cjbiker OP
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,657
With all the positive reviews on the pre-filter and Head2Wind jetting, I've never read any complaints about starting. I'm sure some small adjustment will fix it. I'm not ready to throw in the towel yet.
Old 06-04-2014, 06:53 AM   #10
ABuck99
0.0
ABuck99's Avatar
Oddometer: 595
You might check in with Ken since you bought his jetting kit- he'll have the right answers.
Possible that your idle adjustment is set too high- once you get it running and warmed up, set to 1500/1600rpm and see how it restarts. Also, when you take the carbs off its a good idea to synch them after you re-install. Also did you check your TPS?
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 06-04-2014, 06:57 AM   #11
cjbiker OP
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,657
Idle is 1400-1500. I didn't sync the carbs or mess with the TPS.
I was hoping he would chime in here, I'll give him a call. I bought the kit used in the FM here, so I'd understand if he doesn't want to help me.
On another note, when I started it this morning, I held down the starter button while slowly pulling on the choke. Once it was about half way out, it lit right off.
Times are GMT -7.   It's 12:17 AM.
