Old 06-03-2014, 03:18 PM   #1
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 592
Gas Spewing out of cylinder HELP PLEASE
Please check out this video of my problem... If you have any ideas Id love to hear them. I recently installed a Facet Fuel pump then this started...
http://m.youtube.com/watch?feature=y...&v=-qBQWn-i6XI
"if your not getting older, your dead"
rossphoto is offline   Reply With Quote
Old 06-03-2014, 03:19 PM   #2
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 592
help
Im thinking I may have got some dirt in a line and a float is stuck??? Could that cause this?
Old 06-03-2014, 03:25 PM   #3
Monty_Burns
Excellent.
Monty_Burns's Avatar
Oddometer: 1,291
You are probably right. Which Facet pump did you install?
Monty_Burns is offline   Reply With Quote
Old 06-03-2014, 03:39 PM   #4
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 592
Facet 40171
Old 06-03-2014, 03:56 PM   #5
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,571
You got it.
2013 KTM 690R Enduro
Chuckracer is offline   Reply With Quote
Old 06-03-2014, 04:03 PM   #6
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 592
So all I (hopefully) need to do is remove and clean the carbs???
Old 06-03-2014, 04:45 PM   #7
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,571
Could be as simple as a speck of dirt on the needle seat, but best to pull 'em, get 'em on the bench and see what's going on in there.
Have any adjustments to do? Now's the time.
Old 06-03-2014, 04:48 PM   #8
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,278
Been there, done that. It looks like the float needle is stuck open, which allows gas to continue to flow into the bowl until it flows out of the vent tube. Pull the carbs completely, clean them out completely making sure that you disassemble the floats and needle valves, and blow compressed air through the float needle seat.
Based on the age of the bike, also make sure that the fuel inlets are not leaking. There are tiny little O-rings on each inlet that can fail due to age. The O-rings are hard to find. CJ Designs sells a little packet of the right O-rings: http://www.cjdesignsllc.com/products...-ring-kit-lc8/ I'm sure that's not your problem, but it's good to have that kit of O-rings around. Mine failed just before a trip to Colorado last September. My carbs are still working on a crazy mix of odd O-rings we found in a spare O-ring box that we think included O-rings from a D.I.D. chain. Those bolts holding the inlets in place are put in with red Loctite at the factory and VERY hard to remove {think hammer and chisel}.
Anyway, your problem is a stuck float. Start there.
Orangecicle is offline   Reply With Quote
Old 06-03-2014, 04:54 PM   #9
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 592
Awesome... I'm gonna take it apart tomorrow and super clean. At the moment I don't have that O ring kit. I will order it tho and replace them as soon as it gets cold this fall...
Old 06-03-2014, 04:57 PM   #10
Scribe
£Bob£
Scribe's Avatar
Oddometer: 7,734
Op doesn't mention the year of the bike, but I assume carbs due to he facet pump. If this thing was pouring that much fuel into the cylinder would it even be running?
"Do or do not. There is no 'try.'"
— Yoda
Man Ball Rolls Through Coloutahrado 2014!
Scribe is offline   Reply With Quote
Old 06-03-2014, 05:08 PM   #11
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 592
Its a 2005.5 950 ADV
Old 06-03-2014, 05:12 PM   #12
Orangecicle
On a "Quest"
Oddometer: 3,278
Video shows an orange machine with a black decal, meaning it's a 2004 to 2005.5 US. That's about when you hear about carb inlet failures.
Old 06-03-2014, 05:14 PM   #13
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 592
I went ahead and ordered the o ring kit. Im gonna take it all apart and clean then wait for the kit to arrive to put back in. Better to go ahead and do it while the carbs are out.
Old 06-03-2014, 05:15 PM   #14
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 592
Should I remeasure and adjust the floats exactly???
Old 06-03-2014, 05:44 PM   #15
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,571
Yes. This is important to proper running. There should be lots of info here...search this thread, "Float" or "Floats". Single word searches work best...if at all.
Times are GMT -7.   It's 01:32 PM.
