Old 06-03-2014, 05:46 PM   #16
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 608
Thanks there is also some really good info on that in the Hall of Wisdom
"if your not getting older, your dead"
rossphoto is offline   Reply With Quote
Old 06-04-2014, 05:29 PM   #17
Oldebonz
Oddometer: 55
Smack the float bowls with the plastic handle of a screw driver first,might just be stuck float,happened occasionally on older bikes,especially if sitting for a while,worth a try before dismantling some rather tricky carburetors,then ride the crap out of it if it works.Floats don't come out of adjustment very often,probably a speck of something between needle and seat,corrosion between the float pivot and pinot deteriorating Viton rubber tip on needle. Hope this might help,scary thing when gasoline is pissing all over the bike! No holes or splits in fuel line up by carburetors??
Oldebonz is offline   Reply With Quote
Old 06-04-2014, 06:23 PM   #18
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 608
Prolly good advice, I already got em out tho and since Im planning a RTW (leaving in march) I have decided to go ahead and have em ultrasonically cleaned and put new o rings in all around... Floats need to be at 15mm right???
Old 06-04-2014, 06:46 PM   #19
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 904
Float height
If your floats are at 15 mm then thats why you are spilling fuel. 3mm to 4 mm on the float height.
dogsslober is offline   Reply With Quote
Old 06-04-2014, 06:49 PM   #20
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 608
Not sure where thet are at the moment. I havent personally set the height yet. I asked 15mm because of this
http://www.ktm950.info/how/Orange%20...ng_height.html
Old 06-04-2014, 06:50 PM   #21
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 608
That must be for a different bike
Old 06-04-2014, 07:26 PM   #22
dogsslober
dogsslober's Avatar
Oddometer: 904
Those are NOT 950 carb's, Its just to show how to do the measurement.
Old 06-04-2014, 07:31 PM   #23
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 608
Does anyone know the actual factory specs for float height?
Old 06-04-2014, 07:37 PM   #24
dogsslober
dogsslober's Avatar
Oddometer: 904
3mm
Old 06-04-2014, 07:44 PM   #25
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 608
thnx
Old 06-05-2014, 01:01 AM   #26
ata
expat in the jungle
ata's Avatar
Oddometer: 2,284
Yesterday I finished repairing that fault in an SE, not difficult but laborious
no o-ring or needle damaged, just a bunch of crap inside carburators
good luck
Youth is wasted on the young
Need some help<<<<<<>>>>>>> wet wanderings
ata is offline   Reply With Quote
Old 06-12-2014, 12:25 PM   #27
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 608
OK Carbs clean leak stopped. Now since I put the carbs back in its idling at 1100 1200 so thats good but hearing some loud backfiring pops every second or two. Is this a mixture or a sync issue?
Old 06-12-2014, 12:49 PM   #28
DirtyADV
DirtyADV's Avatar
Oddometer: 2,284
The link you had questioning 15mm also has another link going to a 950 specific carb:
http://www.ktm950.info/how/Orange%20...own_gauge.html
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 06-12-2014, 03:39 PM   #29
keener
Speed changes you.
keener's Avatar
Oddometer: 928
since this happened right after you put a new pump in, I bet you left some dirt or something in the lines after the pump that got stock at the float valve. Glad you fixed it. Those orings will come handy later.
For the backfiring issue. I put my money on incorrect idle mixture screws (IMS) settings. You must have tightened them all the way in or something like that.
04 ADV 950
keener is offline   Reply With Quote
Old 06-12-2014, 04:54 PM   #30
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 608
is there a standard setting for the IMS like 2 1/4 turns out from all the way in?
Times are GMT -7.   It's 07:31 PM.
