Old 06-04-2014, 05:19 AM   #1
joan-gs OP
If I were a rich man.....
joan-gs's Avatar
Oddometer: 55
950 SE air filter Maintenance with Rotweiller
Hi,
One issue I hate most from SE is each time I want to clean the air filter, you know, remove tank or tilt, unscrew cover and back agin. So, an action that must be done almost each "on any sunday" when offroading become horrible.
My question to the Rotweiller filter owners: Can you remove the filter without removing the series tank or the Safari tank? In pictures I can see a gap, together with no tools needed, I bet that the answer is positive, but would like to get your experience.
thx
joan-gs is offline   Reply With Quote
Old 06-04-2014, 05:23 AM   #2
johnno950
Oddometer: 1,076
Originally Posted by joan-gs View Post
Hi,
thx
Rotty can be removed with tank on,just unclip seat (thats with the oem tank,sure no problems with safari but check),fantastic bit of kit the rotty system.
johnno950 is offline   Reply With Quote
Old 06-04-2014, 08:10 AM   #3
Headbeater
Oddometer: 49
Like Jonno stated, I can easily remove the seat and gain access to Rotty air filter without removing my fuel tank, I run a PC filter skin that help keep my filter clean.
Headbeater is offline   Reply With Quote
Old 06-04-2014, 09:42 AM   #4
SpeedyR
SE in the SE
Oddometer: 889
easy to do with the safari tank as well. I just put on latex gloves to reach in there to unhook/remove everything, as it keeps the filter goop off my hands but yes it's easy.
SpeedyR is online now   Reply With Quote
Old 06-04-2014, 11:51 AM   #5
Iflylo
Iflylo's Avatar
Oddometer: 22
Piece of cake.70 mm between safari tank and the top of the filter.Seat off ,twist two "D" shackles and off.
Iflylo is offline   Reply With Quote
Old 06-04-2014, 02:10 PM   #6
oldfuddy
oldfuddy's Avatar
Oddometer: 634
the ability to service the air filter on the SE w/o removing the tank is worth the money alone for the Rotty… I just use skins over mine.. takes about 2 minutes to pull the seat, pull off an old sock, put on a new sock, and then put the seat back on. of course add time if/when you must service the entire filter and remove it, but if you're using socks you can significantly decrease how often you need to remove the entire filter..which as others said, can still be done w/o removing the tank.
oldfuddy is offline   Reply With Quote
Old 06-05-2014, 01:04 AM   #7
joan-gs OP
joan-gs's Avatar
Oddometer: 55
Convinced! Thanks!
Old 06-05-2014, 01:06 AM   #8
ata
expat in the jungle
ata's Avatar
Oddometer: 2,288
fuck you and do it, you lazy fuck
try to relocate the fuel pump (or mount a facet one) and all the process won´t last half an hour
moñas
Youth is wasted on the young
Need some help<<<<<<>>>>>>> wet wanderings
ata is offline   Reply With Quote
Old 06-05-2014, 01:27 AM   #9
johnno950
Oddometer: 1,076
Convinced! Thanks!
Lots easier to service etc,no doubt you will be more than impressed with the performance side of things when fitted,you can go riding all day and be back before lunch.
Old 06-05-2014, 04:59 AM   #10
joan-gs OP
joan-gs's Avatar
Oddometer: 55
Half an hour is still too much. You dear little mermaid live almost under the sea and have no problems with dust.
Where to put the Facet out of original location?
Old 06-05-2014, 07:05 AM   #11
ata
expat in the jungle
ata's Avatar
Oddometer: 2,288
TIP 1
TIP 2
TIP 3
You´re welcome
Times are GMT -7.   It's 07:44 AM.
