Old 03-19-2014, 01:05 PM   #2986
Harvey Krumpet
Oddometer: 908
Originally Posted by wah64apache View Post
Hello Ladies and Gentlemen;
Just purchased a 93 TDM 850 from Texas. Haven't picked it up yet as I am in Arizona and can't get over there for a bit.
The bike has 10K on the Odometer and looks very clean and tidy. Close-up pics were provided of all areas. Not perfect but very nice for its age.
My plan is to fly to Houston, get the bike, spend a few days with old friends and then embark on a back road trip along the coast, across S of San Antonio, along the US side of the border then into Big Bend for a few days. On to El Paso, across S New Mexico and then via the Arizona BCDR from Benson to Globe, then home to the E Valley of Phoenix.
I'm new to the TDM, not to bikes in general, and especially not dirt or ADV bikes.
My question to you of the TDM persuasion is what items peculiar to the TDM should I change before departing, and what should I carry as spares, again peculiar to the TDM.
Thanks in advance for your advice, it will be heeded. Cheers, Frank
PS. If anyone is along the route and wants to meet for coffee in the am or beer in the pm, let me know. F
Oil. Most 850's use oil with sustained big throttle openings. Nothing to worry about. A flexi necked funnel makes life a lot easier for top ups. I use a 40mm bit of wood under the side stand to get the bike close to level when checking the sight glass. AKA the window of mystery. Don't over tighten the chain, IIR it should have 30 - 50mm free play but double check, I'm old. Maybe something to cosset your bum, sounds like a fair bit of saddle time.
Otherwise just your standard fluid & mechanical checks before you hit the road. Coolant, tires, brakes etc. If the bike has been loved it will probably just thump along quite happily. It's what they do.
Enjoy your trip.
Harvey Krumpet is offline   Reply With Quote
Old 03-19-2014, 06:03 PM   #2987
wah64apache
Older Than Dirt
Oddometer: 64
Enjoy your trip.
Thanks for the advice Harvey. How are things shakin' down under? And do you look like Harvey? Kidding aside, good advice. Thanks, cheers, frank
wah64apache is offline   Reply With Quote
Old 03-20-2014, 01:51 AM   #2988
Harvey Krumpet
Oddometer: 908
I'm not in the shaky bit, we has cyclones instead. I hate to say it but me & HK do have similarities. Beyond naturism & Ugg boots.
If your looking for specific info pop into http://www.carpe-tdm.net/ipb/
Bring cake.
Old 03-20-2014, 09:01 PM   #2989
wah64apache
Older Than Dirt
Oddometer: 64
I don't like Pavlova, too sweet fo me. And I doubt anyone wears Ugg boots here in Phoenix, kaboy boots are a different story.
Cheers, Frank
Bring cake.
Old 03-22-2014, 09:38 PM   #2990
scout18
scout18's Avatar
Oddometer: 939
Welcome Wah64, I'm just in the process of actually going on a ride tomorrow on my TDM for our first real shakedown together other than a few tests as changes have been made. I've put a Michelin PR 4 on the rear and still have the BT06 on the front as my Michelin for that end hasn't shown up yet. Since I have had it I have put on a Givi wing rack a Kerker exhaust that came with it and Pro Taper SE bars. On the short rides I've taken I am very impressed with how it goes. My main bike is a KLR 650 so it doesn't take much.
Alis Volat Propiis
scout18 is offline   Reply With Quote
Old 03-23-2014, 01:42 PM   #2991
Harvey Krumpet
Oddometer: 908
What are your thoughts on the Kerker? I have a 2 - 2 and it's rather fruity. Definitely improves mid range & bottom end, too.
Old 03-24-2014, 09:21 AM   #2992
scout18
scout18's Avatar
Oddometer: 939
I took on a 200 mile poker run this weekend with very mixed riding from free way to super tight twisties. Wow. I'm very
pleased with the kerker which amounts to basically straight
pipes with shiny cans. I like it a bunch just loud enough 1/2 the weight of the stocker.
cans.
Alis Volat Propiis
Old 03-25-2014, 10:50 AM   #2993
SlipChip
Adventure Commuter
SlipChip's Avatar
Oddometer: 3,386
When you first get there, make sure the owner starts it from cold for you. If it has to crank for a bit then the vacuum fuel pump is probably weak. Normal mod is electric fuel pump to fix.
Chip
`92 Yamaha TDM 850
“Discoveries are often made by not following instructions, by going off the main road, by trying the untried.” - Frank Tyger
"Life begins at the end of your comfort zone." - Neale Donald Walsch
SlipChip is online now   Reply With Quote
Old 03-26-2014, 07:09 PM   #2994
scout18
scout18's Avatar
Oddometer: 939
Take a voltage meter with you and make sure it's putting out more than 12 volts after it's running
Alis Volat Propiis
Old 03-31-2014, 05:17 PM   #2995
wah64apache
Older Than Dirt
Oddometer: 64
Fuel pump replacement
Thanks, I understand that the FZR electric fuel pumps from the early 90's are a good fix for the weak vacuum pumps. Cheers, Frank
I was asleep at the wheel here, I was thinking of my MG Quota that I replaced the headlight with an early 90's FZR item. F
wah64apache screwed with this post 04-01-2014 at 08:58 AM
Old 03-31-2014, 05:20 PM   #2996
wah64apache
Older Than Dirt
Oddometer: 64
TDM charging system
[QUOTE=scout18;23789250]Take a voltage meter with you and make sure it's putting out more than 12 volts after it's running[/QUOTE
Scout, is the issue the Voltage regulator/rectifier or the stator? cheer, frank
Old 03-31-2014, 08:33 PM   #2997
clocklaw
clocklaw's Avatar
Oddometer: 1,995
The R/R is the issue, apparently go out every 28 - 30 k
2005 FJR1300 - "my Blue Angel" 2005 FZ1 - "Shazaam"
My Twins are Twins!
1992 TDM850 - "Ginger" & 1993 TDM850 - "Raven"
clocklaw is offline   Reply With Quote
Old 03-31-2014, 11:09 PM   #2998
itsatdm
itsatdm's Avatar
Oddometer: 4,902
Mine lasted 50,000 miles. At the time replacement R/Rs were cheap on E bay, so I bought 2.
Old 04-01-2014, 05:52 AM   #2999
scout18
scout18's Avatar
Oddometer: 939
Yes often if the r/r goes out it can take the battery and stator with it. Good to have an extra one on board with you if you're going traveling on it the r/r gets hot anyway and it's location on the bike may be good for weather protection but not ideal for heat dissipation.
Alis Volat Propiis
Old 04-01-2014, 07:08 AM   #3000
TeDeeM
TeDeeM's Avatar
Oddometer: 8
Hi all !
A few months ago I bought new TDM 900 and in this stage I am testing my bike on weekend rides . There is still few things to add and improve so I hope for Your advices based on experience .
I am surprised with handling and power delivery but I would like to reach adequate set up for longer tours and for use on dirty roads if neccesary.
Here are few pics :
(Powered by frubar.net)
TeDeeM is offline   Reply With Quote
Times are GMT -7.   It's 09:43 AM.
