Old 06-16-2014, 06:00 AM   #1
Bill the Bong OP
Supern00ba
Bill the Bong's Avatar
Oddometer: 976
Wireless Bicycle Computers as ICO back-up
Anybody here used a wireless bicycle computer as a back-up to the ICO? Did the bike's electronics interfere? Using a wire-type bicycle computer is well documented, but running the wire along with ICO's wire might duplicate the failure mode.
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 06-17-2014, 07:50 AM   #2
Bill the Bong OP
Supern00ba
Oddometer: 976
I'm proud to say that I finally had a question that nobody could answer. Suppose I should just test it myself.
Old 06-17-2014, 08:02 AM   #3
640 Armageddon
-oo-
640 Armageddon's Avatar
Oddometer: 2,814
Well.... There are other threads that this has been addressed, and I will only say my personal opinion.
If I was to have a backup, I would have to make sure that it would not let me down. Ever. Otherwise we call it something else. Bicycle computers, as their name suggests, are for bicycles. For starters you cannot correct the distance. Then it's difficult to set the wheel diameter in most of them. I have seen them fail, (twice) even before a race.
You are looking for a cheap solution? Go Trailtech. It's all about how bad you want to finish the race. Otherwise, if its a friendly ride, you may as well go with one trip. Or use pilo's iphone application http://www.advrider.com/forums/showthread.php?t=936183 (he is an inmate here) and you are good to go!
Aurora Rally Equipment - Rally parts with lifetime warranty
"Do or Do Not. There is No Try" - Yoda
640 Armageddon screwed with this post 06-17-2014 at 08:17 AM
640 Armageddon is offline   Reply With Quote
Old 06-17-2014, 08:15 AM   #4
wsmc831
wsmc831's Avatar
Oddometer: 775
I used a wired version at one point, the wireless versions didn't record a high enough speed. Getting wheel distance was easy, and it worked fine other than no backlight.
97 TL1000S
2010 690 EnduroR
2013 500 Exc
wsmc831 is offline   Reply With Quote
Old 06-17-2014, 11:05 AM   #5
Bill the Bong OP
Supern00ba
Oddometer: 976
Perfect, thanks
Old 06-18-2014, 03:30 AM   #6
GezwindeSpoed
GezwindeSpoed's Avatar
Oddometer: 262
I also used a wired one in my first rally. You have to ride on partial distances (so zerro it every tulip). I soldered a wire with button on one of the computer button which made it operatable by your thumb.
FE570; CB500X; KLE500
GezwindeSpoed is offline   Reply With Quote
Old 06-18-2014, 09:44 AM   #7
Bill the Bong OP
Supern00ba
Oddometer: 976
Thanks, I appreciate the feedback. I have an ICO, just looking for an affordable back-up. I hoped that a wireless version would work, as this will mitigate the risk of the wires being damaged.
Old 06-18-2014, 09:59 AM   #8
wsmc831
wsmc831's Avatar
Oddometer: 775
Have you had problems before? I don't think that was an issue more than once or twice in 7 years of racing enduro's. I just taped the ico wires to the brake line, and if it was damaged I just replaced it with a hard plastic covered version from motionpro.
97 TL1000S
2010 690 EnduroR
2013 500 Exc
Old 06-18-2014, 11:55 PM   #9
Bill the Bong OP
Supern00ba
Oddometer: 976
Fair enough.
Old 06-19-2014, 01:30 AM   #10
troy safari carpente
Team f5ool
troy safari carpente's Avatar
Location: "Pearl of the sound" - f5ederation of scandwegia
Oddometer: 20,467
+1
My experience with bicycle trip computers has been (and I seen a LOT of them in the period 1988 to around 2008-ish) is that they more often than not; fail... due to the fact that they are engineered with completely another purpose, and harshness of environment in mind.
IF you are looking for a "back up" system... Why would you choose something that is inherreently LESS likely to (still) be in working condition, when (and if) the purpose built (and generally reliable) ICO tripmeter might fail?
You can jerry rig any number of different bicycle trips to do what you ask about (either wireless or with a lead to the wheel sensor/magnet). But in my experience, the liklihood that the unit will STILL be operational, in the event the ICO fails and you need to call on the "back-up" is only about 1 in 20...
CONTENTS MAY SETTLE DURING TRANSPORT...
troy safari carpente is offline   Reply With Quote
Old 06-19-2014, 01:58 AM   #11
640 Armageddon
-oo-
Oddometer: 2,814
Or!
You can use the bicycle trip as a main tripmeter and have tha ICO as a backup
Old 06-19-2014, 02:42 AM   #12
Team f5ool
Oddometer: 20,467
Originally Posted by 640 Armageddon View Post
Or!
Greeks...
You're the blokes that came up with the idea for airbag equipped parachutes... aren't you...?!
Hi d'...
Old 06-19-2014, 02:44 AM   #13
GezwindeSpoed
Oddometer: 262
Or buy a EXC remote for the standard 690 tripmeter. Disadvantage is that you can only adjust trip2 on a stand still.
Old 06-19-2014, 03:20 AM   #14
640 Armageddon
-oo-
Oddometer: 2,814
Originally Posted by troy safari carpente View Post
Greeks...
Hi d'...
Hey Troy
what's wrong with that?!
Well... If only we had a Greek James Bond eh?
Old 06-19-2014, 03:32 AM   #15
Team f5ool
Oddometer: 20,467
Yeeeeah...?
... he probably wouldn't have survived the first episode... and Ian Flemming's lifes work would have ground to an abrupt halt right then back in the 60's...
Times are GMT -7.   It's 05:27 PM.
