Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 06-25-2014, 08:01 AM   #31
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,297
my solution
went over to the neighbor's shop to cut a piece of stainless for the foot pad, and he had a 5 gallon bucket with cut outs from the SS tanks they build, so for now I just grabbed one of them, drilled a couple holes and mounted it up with stainless flat head bolts. If it's not big enough, I'll do something different. Might even take a DA to it and "fancy it up" a bit.
PineyMountainRacing is online now   Reply With Quote
Old 06-27-2014, 09:35 PM   #32
kag
Wander Lust
kag's Avatar
Oddometer: 1,636
From my shop
I have a box of these. I went out and just placed it on the bottom the foot and it matches up really well. Need to play with it and come up with a way to mount it, I could just cut cut the OEM pad off and weld this on after hitting the edges on the grinder. But i would rather come up with a way to mount it and leave the existing foot in place and not just weld it on. The steel is good quality.
Maybe some one has a good idea
“Always drink upstream from the herd”
2007 Yamaha TW 200 / 2008 Buell Ulysses
2013 Triumph Tiger 800r / 2014 KTM 1190 EDS
kag is offline   Reply With Quote
Old 06-27-2014, 10:29 PM   #33
davehg
Oddometer: 49
Ordered the Camel Toe off EBay. Yeah, there are cheaper side stand plates available, but this will have me smiling every time I put the side stand down.
davehg is offline   Reply With Quote
Old 06-28-2014, 12:44 AM   #34
kag
Wander Lust
kag's Avatar
Oddometer: 1,636
Show the bottom of it....I hear the bolts do not sit flush
Old 06-28-2014, 05:11 PM   #35
kag
Wander Lust
kag's Avatar
Oddometer: 1,636
Just need to clean up the weld with the grinder now. Rolled bike out into the yard, lots of rain last night so the ground is soft. Works great, the bike stayed upright.
Old 06-28-2014, 05:35 PM   #36
KTMforget
KTMforget's Avatar
Oddometer: 838
Getting closer. One more revision. Still waiting on pricing.
Kurt - Black Dog Cycle Works
Check out our new website: BLACK DOG CYCLE WORKS
We specialize in the best parts for BMW and KTM Adventure bikes. WE TEST WHAT WE SELL!! Not just MADE in the U.S.A., made BETTER!
KTMforget is offline   Reply With Quote
Old 06-28-2014, 06:13 PM   #37
Cuchulainn
Y.Me
Cuchulainn's Avatar
Oddometer: 33
Aren't there two different versions? One with button bolts and one with countersunk bolts? Do neither sit flush?
Cuchulainn is offline   Reply With Quote
Old 08-20-2014, 09:10 PM   #38
phme910
Oddometer: 87
I have a 2014 1190 Adv R & found the kickstand too long & the foot pad too small.
After I installed the "awesome" Black Dog bash plate, I found the kickstand too long.
I got my local welder guy to cut 1/2" off & replace the factory pad with a large washer disk. Cost $20 CDN!!
Looks great!
I did order a SW Motech pad from a Vicious Cycle, our Canadian Twisted Throttle dealer & they sent me a 2013 pad which didn't fit. They told me I had to wait until they get them from Germany; this was 2 weeks ago. Refund $67 CDN
Ahead $47 CDN & happy! :)
phme910 is offline   Reply With Quote
Old 12-12-2014, 01:54 AM   #39
rsser
rsser's Avatar
Oddometer: 232
Beware SW-Motech clearance
A day spent with the virgin 1190 was enough to persuade me to get a side stand extender and I opted for the SW-Motech.
The first ride resulted in what is shown in the pic. What I think happened is that the extended base plate got scraped, pulled back and as a result the retaining plate is bent. This is what happens it seems when you're cranked over and hit a bump that compresses the suspenders.
The supplier says it's not going to be covered by warranty as the unit's not defective. He's sold hundreds he says and this is the first problem he's heard of. What epic service.
Anyone else found this?
Cheers, Ern.
Event in progress.
rsser is offline   Reply With Quote
Old 12-12-2014, 01:49 PM   #40
TimOz
Oddometer: 26
Hi Rsser,
I have to support SW Motech on this one. I have the same stand plate and it was the first farkle I bought. It is very well made and really does not reduce the cornering clearance very much at all. I would think you just had very bad luck. A Melbourne pothole?
In fact it may be that the plate bending helped you. If the lean was great and the bump was big, a very solid hit to the stand could lift the rear tyre off the road a get you into a lowside.
TimOz is offline   Reply With Quote
Old 12-12-2014, 02:23 PM   #41
rsser
rsser's Avatar
Oddometer: 232
Hi Tim,
You haven't dragged yours?
This one happened on what for me was a pretty mild run through Black Spur, Reefton etc. 200 km. Never bottomed out so I'd say there's worse to come unless I get the angle grinder out.
Sure, the retainer plate may have helped but the cost of sacrificial plates might bankrupt me!
Cheers, Ern.
Event in progress.
Old 12-12-2014, 02:32 PM   #42
BrightSight
Oddometer: 13
Rsser - Thanks for the heads up
Your photo clearly indicates that the design of the SW-Motech side stand foot-extender could be improved. If I ever get one, I would consider grinding down the pavement-contacting edge before installation. Thanks.
BrightSight is online now   Reply With Quote
Old 12-12-2014, 03:33 PM   #43
pizzaboy
retiring tomorrow
pizzaboy's Avatar
Oddometer: 1,105
1190 R or S ?
I have one on my R, no dragging
'09 BMW R1200GSA
'09 KTM 950SER Erz 03/08 BD
'14 KTM 1190 Adventure R 03/14 BD
pizzaboy is online now   Reply With Quote
Old 12-12-2014, 03:34 PM   #44
rsser
rsser's Avatar
Oddometer: 232
Standard.
Cheers, Ern.
Event in progress.
Old 12-12-2014, 04:22 PM   #45
rsser
rsser's Avatar
Oddometer: 232
Well I've just pulled it off and ground the plate back a bit. The retainer now overhangs a bit at that corner. Suck it and see.
The rear preload is as it was from the factory. I could get more clearance by cranking it up or by ramping up the compression damping but it feels comfy as it is. 77 kg rider; no luggage.
Cheers, Ern.
Event in progress.
Times are GMT -7.   It's 07:15 PM.
