Old 06-19-2014, 09:19 PM   #1
CCCC OP
Oddometer: 302
990 adventure R 2011
Hi guys
Does anyone know how to adjust the idle speed with TuneECU. I want to lower the idle by about 100rpm
CCCC is offline   Reply With Quote
Old 06-20-2014, 06:10 AM   #2
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 958
You must connect tuneecu, read the map, apply the rpms value changes in the idle table, save it and download the map into the ecu again.
easy
690R
Old 06-20-2014, 09:17 PM   #3
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,148
Originally Posted by CCCC View Post
Hi guys
You can do it. But, don't do it. It's not a harley. Not good for this motor.
"Son, you can't do both"
Old 06-21-2014, 06:05 AM   #4
Grog
Old Bastard
Oddometer: 151
Good advice......
Originally Posted by zuber View Post
you can do it. But, don't do it. It's not a harley. Not good for this motor.
+1
Your ride is in your helmet!
Grog is offline   Reply With Quote
Old 06-21-2014, 12:23 PM   #5
TheRog
Dirtylittle funhaver
Oddometer: 76
07 990 adventure s Dakar
? Should my 990 idle at like 1400rpm
The dealer says they 1, don't know what the idle should be, and 2, you can,t adjust the idle speed, it's controlled by the ecu. So that's why they can't find the spec!
Does that sound like bullshit to anyone besides me.
TheRog is offline   Reply With Quote
Old 06-21-2014, 05:15 PM   #6
CCCC OP
Oddometer: 302
Hi
I realise its not a harley.
Please explain why it will hurt the motor as its idling fairly high compared to normal spec.
Old 06-22-2014, 12:17 AM   #7
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,149
Idle is set at 1470 on most. Much lower = low oil pressure and possible damage.
Verstuurd vanaf mijn LG-D802 met Tapatalk
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 06-29-2014, 12:04 AM   #8
CCCC OP
Oddometer: 302
All fixed. Finally got the cable for TuneECU. Connected and adjusted the throttle cables with the Stepper motor holding fully closed. Now idling 400rpm lower (now within spec) !!!!
Cheers
CCCC
Times are GMT -7.   It's 02:51 AM.
