Old 09-30-2005, 08:59 PM   #1
paulgadget OP
Forever Learning
paulgadget's Avatar
Oddometer: 162
Thumb Garmin 2610(BMW NAV II)
For those that want to use the mapsource topo with the V6 or V7 City Navigator maps, I found a way to do this.
I don't know if anyone else has figured this out but I thought I would post it anyway.
You can load both detail map sets, as much as your compact flash card can hold, I have a 2 gig CF.
Then you can turn off the map sets in the info menus when you want to use either function.
As you know you can't use both at the same time, but if you have the v7 or v6 mapset active and topo off you can auto route to a location and save the route then activate the topo maps and turn off the v6 or v7 (which ever you have installed)
I found this out when I upgraded the maps from V6 to V7 and noticed the detail map files were in larger chunks of land.
I hope this is helpfull to others, if you have any questions just ask in this thread.
Ride on,
Paul
paulgadget is offline   Reply With Quote
Old 10-01-2005, 03:12 AM   #2
NJ_Bob
Occasional Adventurer
NJ_Bob's Avatar
Oddometer: 2,501
How do you switch map sets?
Bob Naumann - W5OV - Sachse, TX - K1300GT - IBA #19100
NJ_Bob is offline   Reply With Quote
Old 10-01-2005, 04:09 AM   #3
ClearwaterBMW
The Examiner
ClearwaterBMW's Avatar
Oddometer: 4,744
Send a message via AIM to ClearwaterBMW Send a message via Skype™ to ClearwaterBMW
there is a menu on the 2610
while on the map, press menu TWICE, i believe
it gives you the choice of picking "map info"
then click there
and you will see all the maps that are on your CF card,
then you can check or UNcheck the map sets you want "active" at that moment
greg
Greg
'07 K1200 GT
'11 R1200 GS Adventure with a DMC M72DX Sidecar
live life like you mean it... but take your family and friends (and DOGS) along for the "ride"
ClearwaterBMW is offline   Reply With Quote
Old 10-01-2005, 04:50 AM   #4
NJ_Bob
NJ_Bob's Avatar
Oddometer: 2,501
then click there
greg
It works - thanks.
Very cool.
P.S. I did it on my 2720. Similar menu selections.
NJ_Bob screwed with this post 10-01-2005 at 05:02 AM
Old 10-01-2005, 05:11 PM   #5
ClearwaterBMW
The Examiner
Oddometer: 4,744
i'm glad it worked/i wasn't sure i remembered correctly
greg
Greg
'07 K1200 GT
Old 10-01-2005, 05:21 PM   #6
PhilSpace
The Gov
PhilSpace's Avatar
Oddometer: 34,179
I've been doing that for a while, but with the old, pre Navteq Metroguide. It rocks, much more detail on back roads, streams, mountain tops w/elevation and fire breaks/trails, just no TOPO info, just the elevation listed for mountain tops with their name.
I use the City Nav for haulin butt and Metroguide for sniffing around the back roads. Turn them on and shut them off at will.
PhilSpace is offline   Reply With Quote
Old 10-02-2005, 11:19 AM   #7
paulgadget OP
Forever Learning
paulgadget's Avatar
Oddometer: 162
I'll have to check that out
Thanks Phil,
I'll check out the difference.
Times are GMT -7.   It's 01:59 AM.
