Old 06-22-2014, 03:50 PM   #1
ADVill OP
Oddometer: 609
fixing small holes in coolant overflow bottle
Very small, above coolant level. Ideas? Doesn't really 'leak'. Doesn't boil out. Losses a little coolant over time, most likely from hard right turns, leaned over.
'08 990 Adventure Orange of course
'00 520 EXC
'14 500 XCW
ADVill screwed with this post 06-22-2014 at 03:56 PM
ADVill is offline   Reply With Quote
Old 06-22-2014, 05:05 PM   #2
renogeorge
Oddometer: 1,396
JB Weld
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 06-22-2014, 05:48 PM   #3
ADVill OP
Oddometer: 609
Thinking the bottle will flex and the jb weld won't
'00 520 EXC
'14 500 XCW
Old 06-22-2014, 05:52 PM   #4
Hill Climber
Oddometer: 364
Sealall
http://www.eclecticproducts.com/sealall.htm
Just clean with TSP then sand the area before applying. Use a plastic patch if you want with the glue
08 ktm530
12 ktm990Adventure
Hill Climber screwed with this post 06-23-2014 at 12:22 PM
Hill Climber is offline   Reply With Quote
Old 06-22-2014, 06:09 PM   #5
ADVill OP
Oddometer: 609
May try that. Thanks.
'00 520 EXC
'14 500 XCW
Old 06-23-2014, 04:19 AM   #6
johnno950
Oddometer: 1,076
my se cracked on the high level mark,i used liquid steel 2 part putty to seal it,worked a treat,i would of replaced the overflow bottle if leak was from base surface.
johnno950 is offline   Reply With Quote
Old 06-23-2014, 07:10 AM   #7
tinwelp
Professional Idiot
Oddometer: 166
Probably the easiest and most reliable fix is to just replace it. Surely it's not that expensive? Or do you just need a solution now?
I'd try common liquid Cyanoacrylate (super-glue), mixed with bicarbonate of soda. Yes, sounds bizarre, but it is remarkably effective at making repairs on semi-rigid plastics. Liquid glue works better than gel types.
The tank must be super clean to ensure a decent bond, although the same's true for pretty much any adhesive. After cleaning with a solvent of your choice, coat the area you want to repair with a thick layer of super-glue. Sprinkle with bicarb, another layer of glue, another layer of bicarb, building up the layers until the hole is filled.
It works and lasts well, and is almost free.
Cheers... Paul
tinwelp is offline   Reply With Quote
Old 06-23-2014, 07:49 AM   #8
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,012
When in turns, liquids stay pretty much orthogonal to the axis of the bike. So coolant doesn't change level inside the overflow walls.
Cheers.
Old 06-23-2014, 11:37 AM   #9
ADVill OP
Oddometer: 609
Guessing I need to get a degree in hydrodynamics...
'00 520 EXC
'14 500 XCW
Old 06-27-2014, 01:19 PM   #10
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 722
Isn't that tank made of polyethylene? I've only heard about specialized 'surface' adhesives (solvent types won't work on the stuff) or hot-air welding for repairs.
HeatXfer is online now   Reply With Quote
Old 06-27-2014, 01:55 PM   #11
Peanuts
Peanuts's Avatar
Oddometer: 1,672
Part Number: 60035065000
Description: WATER EXPANSION TANK 03
Retail: $34.99
Your Price: $33.24 (5% discount)
Hardly worth the risk of a repair failing?
Peanuts is offline   Reply With Quote
Old 06-27-2014, 02:28 PM   #12
ADVill OP
Oddometer: 609
Retail: $34.99
That is certainly THE fix but it doesn't leak. Filled it about 3,000 miles ago and that is the level now.
'00 520 EXC
'14 500 XCW
Old 06-27-2014, 03:00 PM   #13
Somewhere Far Beyond
The Narrator
Somewhere Far Beyond's Avatar
Oddometer: 217
What if the crack gets bigger, hmm?
Duct tape would be the po' man's fix. The kind that has the stronger adhesive. But they're cheap enough so I'd just replace it outright and be done with it. Pretty much same take as on keener's radiator leak issue.
2003 KTM 640 Adventure
Somewhere Far Beyond is offline   Reply With Quote
Old 06-27-2014, 07:22 PM   #14
ADVill OP
Oddometer: 609
Seems to work:
'00 520 EXC
'14 500 XCW
Old 06-28-2014, 09:39 PM   #15
synkt
Oddometer: 3
It should be made from high density polyethylene. The only thing that reliably sticks to polyethylene is more polyethylene ( worked in plastic fabrication for a few years). Hot glue as a filler and a hot butter knife to smear it around will solve the problem. I have patched bigger holes on tanks with that system.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
synkt is offline   Reply With Quote
Times are GMT -7.   It's 10:54 PM.
