Old 07-01-2014, 08:43 PM   #46
jw18
fail
jw18's Avatar
Oddometer: 607
This rocks! IN!
**Lunch (a ride report)**
jw18 is offline   Reply With Quote
Old 07-02-2014, 12:26 AM   #47
Jedi2Rider
Oddometer: 19
Great Idea! I am in.
Jedi2Rider is offline   Reply With Quote
Old 07-02-2014, 04:41 AM   #48
Jeffrode OP
Oddometer: 25
Day9 Harley Encounter in the Badlands
7/1/2014: Today we had a late start due to the fact that it was raining when we got up. The goal however was to leave Sturgis, SD and work our way through the Black Hills and Badlands to Interior, SD.
It had been raining a lot over the night and was still raining in the morning. Does the weather not know we are from Southern California and don’t know how to deal with the elements? Okay, we sat around for a little while hoping for it to clear off and then left.
We got all of our things together and then tried to get down some miles and work our way towards clear sky’s. We first headed though the Black Hills in the morning.
Got a picture at the sign and continued along the ride. We came to numerous historic little towns in the morning. Lots of them were set up as old mining towns and for tourism. One of the old towns we came to had an old Hudson dealership. Kinda cool, since they are not around anymore just show some of the american car history.
We continued through town and ran into many historic car mechanic shop and stores. Really brought you back in time and no it was not Radiator Springs. Ran across a couple stores with a bunch of antiques.
We flowed through the hills on our way to Mt. Rushmore. The are some gorgeous rocks and forests throughout the Black Hills. Did the name have some influence from the black clouds that sits above them just looking at you? Ran into some of the local logging trucks running up and down the road. Finally we arrived at our first destination and looked around for a bit and continued on.
Worked our way to our lunch stop and then towards the Badlands. First we covered miles and miles of rolling hills and farmland in order to arrive at the Badlands. It is really crazy how they are just formed in the middle of nowhere and the weird shapes that these hills formed.
Continued through and there were some spectacular formations in the hills. Worked our way around and rerouted since my dad choose another dirt road and ended up in Interior. We got here around 2:00 pm so we had a short day but it worked perfect.
We changed oil in the scooters and did our laundry. Even though we finished early we still cover 175 miles and had lots of great times. There were some cool curvy roads through the black hills and I even ended up dragging the scooters belly in a corner. For once even though it started out looking like it was going to rain it turned out to be a dry day. Tomorrow is back to being a long day with 300 miles to travel.
Jeffrode is offline   Reply With Quote
Old 07-02-2014, 04:47 AM   #49
Jeffrode OP
Oddometer: 25
Trouble in Scooter Land?
Help: The scooter started making a noise when starting. Does anyone know what the problem could be?
And what I can do to fix it?
Old 07-02-2014, 05:08 AM   #50
Racegun
Single Track Mind!
Racegun's Avatar
Oddometer: 2,561
Question Some ideas
its is difficult to hear over the net, but it sounds like the starter bendix is not engaging the fly wheel....??? and is skipping ....
1. Has it been giving any trouble?
2. Can these be push started?
3. Did you do the oil change correctly, have you done them many times before and therefor feel confident that the oil change was done correctly?
4. When you changed the oil, did you use royal purple.... :loll Just kidding... just kidding...
.....DID YOU DRIVE THRU DEEP WATER?
https://www.youtube.com/watch?v=rY0ENaUA_Uc this might help
you can find lots more like this on the net
If there was a way to observe the moment the starter engages the flywheel that might help...
If there was a way to examine the fly wheel and the starter drive gear...
talk to your mechanic that is familiar with these machines and ask him to listen...
also...it almost sound like the bearing surface of the bendix has no oil
Cheers!
Dave
Racegun screwed with this post 07-02-2014 at 05:25 AM
Racegun is offline   Reply With Quote
Old 07-02-2014, 05:10 AM   #51
Racegun
Single Track Mind!
Racegun's Avatar
Oddometer: 2,561
AND I WAS just going to ask about how they were holding up....
Cheers!
Dave
Old 07-02-2014, 05:23 AM   #52
Jeffrode OP
Oddometer: 25
Turns out they are holding up great, we have logged about 3k miles and this is the only issue. We put a new drive belt on just before starting the ride. And brought the old one with us. The new belt made a vibration in the scooter. So we put the old belt back on and the vibration is fixed. But after putting the old belt back on this starting noise started. ??? Could the old belt be squealing when stating? We can hope to get a new good belt in 3 days in Chicago.
Old 07-02-2014, 06:18 AM   #53
Racegun
Single Track Mind!
Racegun's Avatar
Oddometer: 2,561
i will post this in the section were a lot of smart techs hang out
Cheers!
Dave
Old 07-02-2014, 06:59 AM   #54
MassiveLee
It's a small world
MassiveLee's Avatar
Oddometer: 1,106
Originally Posted by Jeffrode View Post
Help: The scooter started making a noise when starting. Does anyone know what the problem could be? And what I can do to fix it?
If the sound is the starter motor spinning, but not engaging, it could be a very easy fix. My own 1150GSA did it early this spring. The solenoid is simply gripping and the magnetic force is not strong enough to overcome the friction. Simply take the starter apart, clean thoroughly with WD40 and regrease. Check the solenoid and it will most likely show gunked up, or dry.
Time to spend a night in a motel with Wifi, not too far from a car parts shop if you need tools, and spend the late afternoon taking the scooter apart.
Lee
1982 Honda 500 Ascot FT / 1986 Honda 750 Nighthawk S / 1988 Honda 1000 Hurricane / 1990 Honda CBR1000F
2001 BMW K1200RS aka Good Girl -- Current
2006 BMW R1150GSA aka Kim Kardashian -- Current
1988 Honda Africa Twin aka Queen of Sheeba -- Current
MassiveLee is offline   Reply With Quote
Old 07-02-2014, 07:25 AM   #55
ride4321
ride4321's Avatar
Oddometer: 1,947
Really enjoying this report, you guys rock!
Hope that noise is nothing serious.
Don't you know there ain't no devil, it's just God when he's drunk.
Tom Waits
ride4321 is offline   Reply With Quote
Old 07-02-2014, 08:18 AM   #56
Questor
More Undestructable
Questor's Avatar
Oddometer: 4,154
Get any speeding tickets?
Sounds like you guys are having a great time, going slowly enough to see the geology change. It gives you a real perspective about the different parts of the country.
Enjoy the ride and thanks for doing this Ride Report.
Q~
Old 07-02-2014, 08:38 AM   #57
luckychucky
luckychucky's Avatar
Oddometer: 1,256
MO Pics
Looks like fun! I too think it's the bendix, part of the starter, you have a kickstarted, it isn't a show stopper. Probably just as easy to get the whole starter.
luckychucky screwed with this post 07-02-2014 at 08:43 AM
luckychucky is offline   Reply With Quote
Old 07-02-2014, 10:13 AM   #58
judomaniak
judomaniak's Avatar
Oddometer: 171
thats awesome riding scoots across the states. great way to see the sceenery. drive safe and have fun. subscribed
2009 honda varadero
judomaniak is offline   Reply With Quote
Old 07-02-2014, 11:19 AM   #59
jub jub
frumiousbandersnatch
jub jub's Avatar
Oddometer: 15,017
I'm loving this. Hope you can figure out what's causing the noise.
jub jub is offline   Reply With Quote
Old 07-02-2014, 03:00 PM   #60
Todd78d
Oddometer: 11
Keep scooting
Thanks for sharing you ride. Love the story, pictures and that it's father & son.
Todd78d is offline   Reply With Quote
Times are GMT -7.   It's 10:20 PM.
