Old 06-25-2014, 09:51 AM   #1
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 602
Anyone use this
Anyone have experience with this??? Thoughts?
http://www.ktmtwins.com/scotts-ktm-9...lc8-oil-filter
"if your not getting older, your dead"
rossphoto is offline   Reply With Quote
Old 06-25-2014, 09:58 AM   #2
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,474
http://advrider.com/forums/showthrea...ghlight=Scotts
Just one of many many many discussions on this forum about these filters. Please search first!
For Sale: 2012 KTM 990 Adventure
Chuckracer is online now   Reply With Quote
Old 06-25-2014, 10:57 AM   #3
Dan Diego
Oddometer: 1,024
Note: "if you're not getting older, you're dead"
I mean, whatever kills you kills you, and your death is authentic no matter how you die.Jerry Garcia
+1. C'mon, DeadHead!
I have no interest in living a balanced life. I want a life of adventure.
Dan Diego is offline   Reply With Quote
Old 06-25-2014, 11:15 AM   #4
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 602
OK OK OK .... Ive been on here a while. the search engine sucks a little bit right Ill look harder next time...
Old 06-25-2014, 11:25 AM   #5
effensteve
Enjoying the ride
effensteve's Avatar
Oddometer: 734
Use google for for your search engine.
But,........ Stainless doesn't show waves when it gets water in it. The stock filter is sort of a diagnostic tool for these stupid beasts.
effensteve is offline   Reply With Quote
Old 06-25-2014, 11:32 AM   #6
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 602
Found this
Originally Posted by rossguzzi
I think what is meant by the above post is the paper one blocks up if the water pump seal leaks water into the oil system. Hence the wavy pleats when contamination occures.
The S/S one has a bypass valve if I remember correctly. So if the oil water sludge blocks the filter the bypass opens. Better watery oil than none.
Close. Sludge will flow through the SS filter. There is no bypass. When sludge hits the paper filter, the water swells the paper and you get no oil pressure. So, it's up to the end user to decide which way to go. I prefer fluid pressure over the potential of no pressure. Those aluminum cam journals fry quickly in low pressure. Some will prefer the "warning system" of wavy pleats. Whatever. Hope you see the wavy pleats before it's too late!
Old 06-25-2014, 12:49 PM   #7
ADVill
Oddometer: 609
Oh gees the Search Police rears it's ugly head. Who cares? New people would never know it exists if it weren't for new threads.
Let's see I don't know aScotts filter exists so I'll search for it? Yes he knew it existed but OTHERS DO NOT!
Chill...
'08 990 Adventure Orange of course
'00 520 EXC
'14 500 XCW
ADVill is offline   Reply With Quote
Old 06-25-2014, 01:06 PM   #8
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 602
Originally Posted by advill View Post
oh gees the search police rears it's ugly head. Who cares? New people would never know it exists if it weren't for new threads.
Let's see i don't know ascotts filter exists so i'll search for it? Yes he knew it existed but others do not!
Chill...
exactly!!!!
Old 06-25-2014, 01:34 PM   #9
renogeorge
Oddometer: 1,425
A lot of these bikes have oil pressure warning lights--possibly an alternative to pulling out the oil filter to check for coolant
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 06-25-2014, 02:48 PM   #10
rburkat
rburkat's Avatar
Oddometer: 293
Remember also that if you are on a trip and your paper filter gets plugged/pleated and you get no oil pressure, you can just put the bike on the side and remove the filter and get home. Better to circulate dirty oil than no oil.
rburkat is offline   Reply With Quote
Old 06-25-2014, 04:06 PM   #11
boat.man
Chief bottle washer
boat.man's Avatar
Oddometer: 179
I am not sure why there is so many people scared of these things?
I have had them in several bikes and have had one on my 07 990 sense oil change #2. My bike has 50K miles on it. The bike is on the original clutch and 2nd water pump, Now i have a CJ pump in it. I find it easy to clean and also see what is in the filter. I have a glass bowl that i put some gas or solvent in and throw the filter, screen, drain plug and covers for the filer and screen in. Then blow everything off with compressed air. The bike is running great and shows no sings of issues related to oil.
Buy one and never look back!
When I read about the evils of drinking, I gave up reading.
07 KTM 990 Adventure
06 TE610 Sold
2 sleds
lets go play!!
boat.man is offline   Reply With Quote
Old 06-25-2014, 06:55 PM   #12
SpeedyR
SE in the SE
Oddometer: 942
no
no
SpeedyR is online now   Reply With Quote
Old 06-25-2014, 08:10 PM   #13
ADVill
Oddometer: 609
You have no thoughts? Lucky you!
'00 520 EXC
'14 500 XCW
Old 06-25-2014, 10:17 PM   #14
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,073
My thoughts...
Pressure gauges can go bad. Warning lights can burn. I prefer to have 4 warning alarms than one: cam chain rattle, sludge in the clutch cover, low pressure light on, curved pleats on my oil filter, loosing coolant. Mind you, if SS filter is used and coolant in the oil is not too much, you get no chain rattle, no warning light, no curved oil filter pleats. So you are left with sludge in the clutch cover and loosing coolant only which can go on for a while, until you dive in there.
Cheers.
Old 06-25-2014, 11:28 PM   #15
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,256
I use a Scott's, and my rationale is this: I'd rather let the engine run on contaminated oil than no oil at all.
Coolant loss in the reservoir (verified occasionally by a radiator level check), sludge buildup on the hex cap on the alternator cover-- these I'll rely on to alert me of a water pump problem. I'd just as soon let the oil filter filter oil.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Times are GMT -7.   It's 10:24 AM.
