Old 06-25-2014, 05:17 PM   #16
Orangecicle
Quest Adventurer
Orangecicle's Avatar
Oddometer: 2,721
How to search the site
This might help you. This is an example of how you can really search the site. Google can do a really good job:
http://www.lmgtfy.com/?q=site%3Aadvr...kracer+is+cool
Orangecicle is online now   Reply With Quote
Old 06-25-2014, 06:23 PM   #17
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 599
Now I feel bad!!! I wish we could have a beer. It's all good man!!!
"if your not getting older, your dead"
rossphoto is offline   Reply With Quote
Old 06-25-2014, 06:25 PM   #18
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 599
Originally Posted by HeatXfer View Post
? No shavings to leave behind: With the tensioner cap off the engine, all the work required will be performed on the bench. Once it's drilled & tapped, thoroughly inspect, de-burr and clean as needed prior to reinstalling on the bike.
It's recommended you use a "permanent" thread locker on the oil/flare fitting because you will no longer be able to use an Allen wrench on the modified cam tensioner cap. You could use Vice grips or channel-locks on the cap but that will leave teeth marks.
I hope that answers the question.
Ahhhh now I understand, thanks !!!
Old 06-25-2014, 06:26 PM   #19
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 599
Again thanks!!! Man I love all you guys , even the assholes. Lord knows I've been an asshole many times.
rossphoto screwed with this post 06-25-2014 at 08:15 PM
Old 06-25-2014, 06:52 PM   #20
SpeedyR
SE in the SE
Oddometer: 875
keep it simple.
water in oil
no
yes
SpeedyR is offline   Reply With Quote
Old 06-25-2014, 08:29 PM   #21
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 599
No I guess I don't
The HOW says
I removed the tensioner bolt and drilled and tapped the center with 1/8" pipe threads. Next, I drilled a smaller hole the rest of the way through the bolt with a 3/16" inch drill bit to match the diameter of the 3/16" stainless steel flex hose I used for the oil line to the gauge.
My question is about this part...
"Next, I Drilled a smaller through the rest of the bolt"??? How do you drill a smaller hole through a hole that's already there?
Or am I missing something?
Old 06-25-2014, 09:36 PM   #22
onewoodsrider
Oddometer: 172
Hopefully you didn't drill all the way through the bolt with the larger bit. You only go far enough to tap it for the fitting. I drilled about 3/4 way into the bolt and then drilled the remaining 1/4 way with the smaller bit.
Todd
onewoodsrider is offline   Reply With Quote
Old 06-26-2014, 03:17 AM   #23
Lc8grrr
Vtwin madness
Lc8grrr's Avatar
Oddometer: 442
Originally Posted by Chuckracer View Post
I'm sorry.
Its funny Chuck but being a world wide forum it is easy to take comments out of context, people should put a country in their location as I think this helps members make a judgement on their use of terminology.
950A, 660RR, 640A, 250EXC-2t, RM125C, PE175C, TM250
Lc8grrr is offline   Reply With Quote
Old 06-26-2014, 03:33 AM   #24
Bowber
Oddometer: 180
I've not looked at the instructions for drilling the cap but it's usual to drill using the smallest first then work back.
so drill your small hole through then drill your tapping diameter to the required depth.
Only problem being that you can catch with the larger drill and go too deep by accident if your not experienced and using a hand drill.
Steve
Bowber is online now   Reply With Quote
Old 06-26-2014, 05:34 AM   #25
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,332
And then...sometimes I turn into a raging asshole that surprises even me the next day.
My apologies, Ross, and to the rest of the forum for that disruption.
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 06-26-2014, 05:46 AM   #26
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 599
All good, seriously... A real asshole wouldn't even care...
Old 06-26-2014, 05:47 AM   #27
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 599
Another question on drilling. Whys is the smaller hole even necessary?
Old 06-26-2014, 07:18 AM   #28
woodchuckexc
Oddometer: 801
Chuckracer, why you gotta be such a dick? Not everyone is as smart or cool as you. Have some patience with the rest of us retards!
Saw your apology after i posted. Good on you for manning up. I too have been quick to throw dickhead comments around. Ate my words a few times.
woodchuckexc screwed with this post 06-26-2014 at 07:24 AM
woodchuckexc is offline   Reply With Quote
Old 06-26-2014, 07:26 AM   #29
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 599
OK OK OK Lets drop it... Its all good... Chuck is cool... all is well...
Old 06-26-2014, 01:18 PM   #30
Maoule
Maoule's Avatar
Oddometer: 497
Got to admit,those were some awesome posts flyin' back and forth...and we didn't even have to venture to the basement. Y'all know you're gonna have to go to mass this week, right?
Maoule is online now   Reply With Quote
Times are GMT -7.   It's 03:51 PM.
