Old 06-25-2014, 01:45 PM   #1
midfat OP
wholesome dirtiness
midfat's Avatar
Location: Socal, between the mountains, desert and ocean
Oddometer: 208
950SE "Parking Lamp"
Okay, stupid question. My manual says the lower bulb in the OEM headlight is a "Parking Lamp." It doesn't do anything on my bike. Upon further inspection, it's a bulb with no wires. Not sure if this is an option for non-US markets, or if the previous owner at some point disabled for some unknown reason. I can't find any broken wires in the rats nest behind the headlamp, so I don't thinks it's accident related.
midfat is offline   Reply With Quote
Old 06-25-2014, 01:53 PM   #2
EastSideSM
Isn't that dangerous?
Oddometer: 1,490
Mine looks to be the same ( I have an SM and our headlights I believe are the same.) Mine definitely lights up but barely. It doesn't serve any real purpose other than look like the bulb is barely lit (Think one of those cheap christmas tree bulbs on the green string of lights you can get at walmart). Maybe he disconnected so it was not drawing any juice so he could use the amps for something else he was running?
EastSideSM: '06 950SM Black
EastSideSM is offline   Reply With Quote
Old 06-25-2014, 01:56 PM   #3
buzybraza
buzybraza's Avatar
Oddometer: 379
wierd
It is strange you don't have any wires there. I bought my bike in So.Cal and it has wires and it does work.
I actually use a different switch that allows me to turn everything off and turn it on one step at a time. What I mean is: I can have all off, then just this "parking lamp" you are talking about, then low and finally high beam.
But I never messed with the wire going to to the "parking lamp", I just messed with the switchgear by the left grip.....
buzybraza is online now   Reply With Quote
Old 06-25-2014, 02:09 PM   #4
buzybraza
buzybraza's Avatar
Oddometer: 379
link
Here is a link that shows the switchgear I am using...
http://advrider.com/forums/showthrea...=681267&page=2
Old 06-25-2014, 02:11 PM   #5
midfat OP
wholesome dirtiness
midfat's Avatar
Oddometer: 208
Any chance you can tell me the color combo of the wires that power the bulb? Or, better yet, snap a pic? If I can find the wires in the harness, I'd like to restore them. Seems silly to have a lamp with no purpose.
Old 06-25-2014, 02:12 PM   #6
buzybraza
buzybraza's Avatar
Oddometer: 379
yes
Yes I can do that, but it may take a couple days to post pictures OK?
Old 06-25-2014, 02:26 PM   #7
midfat OP
wholesome dirtiness
midfat's Avatar
Oddometer: 208
No problem at all. Thanks!
Old 06-25-2014, 03:53 PM   #8
midfat OP
wholesome dirtiness
midfat's Avatar
Oddometer: 208
Buzy... Problem solved. I sorted through the wiring diagram and tracked down the leads. PO must have deleted the "Position Lamp" and chopped the wires at the connector. Founds the leads and we're all set. Really appreciate the offer.
Now I'm going to replace the worthless bulb with an LED lamp.
Old 06-25-2014, 04:32 PM   #9
buzybraza
buzybraza's Avatar
Oddometer: 379
good!
Happy you sorted it.
Check out the link above (post #4) anyways for my HID install. Still working good!
Old 06-25-2014, 05:41 PM   #10
oldfuddy
oldfuddy's Avatar
Oddometer: 647
did PO have a Rally Raid designs dakar-type fairing previously installed? That light is not used on the RR set-up and some folks either cut the wires or just tie the wires up out of the way. one way to check would be to see if there are any u-clamp marks (two total) on the neck of the frame.
oldfuddy is offline   Reply With Quote
Old 06-25-2014, 09:23 PM   #11
midfat OP
wholesome dirtiness
midfat's Avatar
Oddometer: 208
No evidence of a Raid fairing. I think it was just chopped for the sake if chopping.
Old 06-26-2014, 07:34 PM   #12
Oilhed
MarkF
Oilhed's Avatar
Oddometer: 4,380
I used the same wires on my GS to charge my GPS. Only hot when on or in park position.
Mark F.
aka OILHED
Central CT
MarkF
BMW R1150GS, Yamaha TW200 & Genuine Buddy50
Oilhed is offline   Reply With Quote
Times are GMT -7.   It's 09:27 AM.
