Old 06-26-2014, 03:20 PM   #1
Hill Climber OP
Oddometer: 347
PIAA H4 60/55=110/100 Xtreme White Bulb for a 990
If there's a post or posts about trying different bulbs on this site, I couldn't find it, (for the self appointed "search police" ) so here's my question:
Has anyone tried one of these?
http://www.ktmtwins.com/piaa-h4-60-5...0-xtreme-white
How does it compare to the stock bulb...
It seems that the only option to gain light output is to spend $235 on the European headlight assembly? Plus another$50 for a good bulb? http://www.ktmtwins.com/piaa-h7-55-110w-xtreme-white
08 ktm530
12 ktm990Adventure
Hill Climber is offline   Reply With Quote
Old 06-26-2014, 05:29 PM   #2
charlie264
charlie264's Avatar
Oddometer: 8,273
Don't waste your money, the reviews favour Philips extream or Osram bulbs, and you get two for the same money. Do a search the Euro reflector, makes quite a difference. Or add a could of LED lamps.
charlie264 screwed with this post 06-26-2014 at 05:51 PM
Old 06-26-2014, 05:49 PM   #3
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,250
http://www.candlepowerinc.com/pdfs/I...verwattage.pdf
Forget the "illegal" part, high wattage bulbs are snake oil.
Chuckracer is offline   Reply With Quote
Old 06-26-2014, 06:27 PM   #4
Hill Climber OP
Oddometer: 347
Thanks for your thoughts... I hadn't thought about the "watt" pitch of the bulb, any higher wattage would result in more amperage (watts = amps x volts)
So you have the euro headlight kit in your bike?
I like the idea of having a separate bulb for low beam
What's the maximum wattage of bulb can one use before you start to melt the refractor? The stock bulb is 60/55 watts, which would draw a maximum of 5 amps. I think the fuse size for the headlight is 10 amps, which means the bulb size could theoretically be 120 watts, but I think the heat build up is what would determine the maximum size of bulb....
08 ktm530
12 ktm990Adventure
Old 06-26-2014, 07:50 PM   #5
Maoule
Maoule's Avatar
Oddometer: 456
FYI, KTMPartshouse lists the euro headlight for $172.
Maoule is offline   Reply With Quote
Old 06-26-2014, 08:30 PM   #6
1Bonehead
Fearless of Falling
1Bonehead's Avatar
Oddometer: 1,113
Part #? Please.
1Bonehead is offline   Reply With Quote
Old 06-26-2014, 08:33 PM   #7
Hill Climber OP
Oddometer: 347
Thank you very much sir. I did not know of ktmpartshouse before now!!!! That's an impressive savings of $63 !!!!!!
08 ktm530
12 ktm990Adventure
Old 06-26-2014, 08:33 PM   #8
Hill Climber OP
Oddometer: 347
Originally Posted by 1bonehead View Post
part #? Please.
60014001000
08 ktm530
12 ktm990Adventure
Old 06-27-2014, 08:59 AM   #9
charlie264
charlie264's Avatar
Oddometer: 8,273
I've the SE, I read an articular that did a test on the PIAA against others, the higher wattage was snake oil as chuck pointed out, its the heat that can cause potential damage and they are illegal in the UK.
Euro reflector is just a better design.
I'll try and find the articles.
http://www.autoexpress.co.uk/accesso...e-light-winter
http://www.advrider.com/forums/showt...=613533&page=2
charlie264 screwed with this post 06-27-2014 at 09:56 AM
Times are GMT -7.   It's 01:06 AM.
