Old 06-26-2014, 03:09 PM   #1
OZbeemer OP
OZbeemer's Avatar
Oddometer: 443
2008 990 with 2010 ECU cure throttle issues?
Does anyone have any advice on if a 2010 ecu in a 2008 990adv fix the snatchy throttle issue?
I've looked at the tuneecu stuff, and I don't feel comfortable playing around with the mapping programs. There is a lot I don't know and don't want to cause any damage.
Wondered if this would be a good alternative.
500cc two-strokes are effective as laxatives too.
-Spikehead
OZbeemer is offline   Reply With Quote
Old 06-27-2014, 08:42 PM   #2
rider911
Shortcut Navigator
rider911's Avatar
Oddometer: 513
Firstly the 2010 ecu is going to look for a immobilizer input and therefore not work until it finds one.
New RR ~ Across OZ... Corner by Corner
08 KTM 300 exce (small)
12 KTM 500 exc (medium)
07 KTM 990 Adv (large)
rider911 is offline   Reply With Quote
Old 06-27-2014, 09:23 PM   #3
OZbeemer OP
OZbeemer's Avatar
Oddometer: 443
Could you explain that a bit more?? I don't know about the immobilize input.
-Spikehead
Old 06-28-2014, 07:14 AM   #4
rider911
Shortcut Navigator
rider911's Avatar
Oddometer: 513
2009 and onwards have an immobilizer fitted to the bike which means you need a matching coded key. Theoretically it would be possible to make it work but you would need the whole set up from the same donor bike. Buying new would be a massive head ache not to mention expensive.
Some people are doing the opposite to what you want to do so as to eliminate the possible disaster if the immobilizer unit fails (and some have) Maybe someone will swap you.
I have a 07 and a 12 and I don't think there's much difference anyway, they're both a touch abrupt on and off the throttle, so what just ride it.
Times are GMT -7.   It's 07:21 PM.
