Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 06-28-2014, 12:54 PM   #1
Tusa OP
Oddometer: 16
Battery Tender for 1190
Does anyone have a recommendation for a good battery charger or tender for an 1190 adventure? Ideally 220v, perhaps available at an European KTM outlet that could be shipped to the US?
Worse case I could get a 110v one I guess and use a transformer.
Thank you
Tusa is offline   Reply With Quote
Old 06-28-2014, 01:19 PM   #2
pks
Oddometer: 37
Thank you
I've had good luck with the Optimate 3 on recent bikes including the 1190. It works better than my Battery Tenders (seems like a better charge profile for AGM/GEL). It is available in 220v according to their web site.
I go direct to the battery though, not through the bike's 12v accy socket, so I don't know what (if any) issues there would be going that route.
http://www.tecmate-int.com/optimate3_plus_detail.php
Paul M
2014 1190 Adventure (build date 10/13)
pks is offline   Reply With Quote
Old 06-29-2014, 07:30 AM   #3
Tusa OP
Oddometer: 16
Wicked
Interesting, thank you.
It hadn't occurred to me that there could be an issue by going in thru the 12v outlet....I'll have to research that. Perhaps somebody in this forum knows about it.
Old 06-29-2014, 07:38 AM   #4
_cy_
Oddometer: 6,437
when charging a battery on a bike .. it's always best to connect direct to battery without possibility of voltage drop interferring with charger.
not a big fan of trickle chargers which are known to kill batteries when left connected for extended periods. AGM and LiFePO4 both have extremely low self discharge. it's better to charge battery to full once a month or so.
find out your parasitic drain and actual AH of battery to determine how long 1150 can sit without killing battery and charge accordingly. better yet disconnect battery when storing bike for extended periods.
_cy_ screwed with this post 06-29-2014 at 07:45 AM
Old 06-29-2014, 12:12 PM   #5
RobZorba
RobS
RobZorba's Avatar
Oddometer: 502
There is no issue charging via the 12v accessory outlet - it's part of the ACC1 accessory wiring which is wired to the battery (permanently on) via a 10A fuse and then the 30A main fuse. There is no "electronics" or "relay contact" in the circuit. The wiring is rated at 10A. Just make sure that whatever charger you use is current limited to less than 10A. Optimate works fine, as does KTM's charger.
P.S. The wires in most "battery tender" leads are rated at less than 10A.
KTM 1290 SA, KTM 1190R, Suzuki VStrom 650 ABS, Honda ST1300, Suzuki SV650, Yamaha RD250
RobZorba is offline   Reply With Quote
Old 06-29-2014, 02:31 PM   #6
_cy_
Oddometer: 6,437
thanks RobZorba sure is nice have specific model information and really glad you decided to stick around Adv!
Old 03-03-2015, 12:29 PM   #7
Quikbrew
Eager
Oddometer: 34
I wanted to connect an electronic battery trickle charger (Optimate 3) to the battery while the bike is sitting. The owner's handbook states that the negative terminals have to be disconnected before attaching a charger "to avoid damage to the motorcycle's electronics" (pg 155 of the 2014 handbook). Is this necessary? I've not done this with any of my previous bikes.
I've always found that using the Optimate 3 has kept my bike batteries in good condition when they're standing for a while between use.
Anybody able to answer this one?
The man hunched over his motorcycle can only concentrate on the current moment. He stands outside of time. He is in a moment of ecstasy. He has no fear/worry. For the source of fear/worry lies in the future, and whoever is freed from the future, has nothing to fear.
Quikbrew is offline   Reply With Quote
Old 03-03-2015, 04:42 PM   #8
john san
Oddometer: 72
I have an Optimate3 that I tried using on the 1190, but always ended up with an MTC failure when I used it. So I switched over to a Battery Tender Plus and have not had a problem. I always charge through the 12v accessory socket. I believe that the Battery Tender will take 120v or 220v input, but check with Deltran to be sure.
- sent from my Moto X Android device.
john san is offline   Reply With Quote
Old 03-03-2015, 08:57 PM   #9
NavigatorCA
Oddometer: 516
Could you plese clarify what "MTC" stands for?
NavigatorCA is offline   Reply With Quote
Old 03-03-2015, 09:18 PM   #10
john san
Oddometer: 72
Motorcycle Traction Control. I believe the system throws that error whenever the voltage gets too high or too low. My guess is that one of the stages of the Optimate3 was breaching the voltage threshold. However, that was with my original defective battery. I have not tried the Optimate3 again since my battery was replaced - might be worth a try just out of curiosity. The same Optimate3 has been maintaining the battery on my Ducati with no problems so I am pretty sure that the device is functioning properly.
- Sent from my ASUS Transformer, powered by Android
Old 03-03-2015, 10:01 PM   #11
Quikbrew
Eager
Oddometer: 34
Thanks for the heads-up on the Optimate 3. OK, so it looks like I need to avoid using that, but what about having to disconnect the negative battery terminal when connecting any charger? Is this necessary?
Old 03-03-2015, 11:02 PM   #12
4bikes
Oddometer: 245
Thank you
I have used CTEK fore many years. Good stuff.
http://smartercharger.com/
4bikes is offline   Reply With Quote
Old 03-03-2015, 11:32 PM   #13
Mr.Metal
Adventure hungry
Mr.Metal's Avatar
Oddometer: 317
I use a Battery Tender Junior, wired through an Eastern Beaver fuse block. No problems.
2015 KTM 1190 Adventure R a.k.a. The Austrian Beast
2009 Aprilia Tuono 1000R a.k.a. Silver Thunder
Mr.Metal is offline   Reply With Quote
Old 03-04-2015, 01:19 AM   #14
Quikbrew
Eager
Oddometer: 34
What about the requirement to disconnect the negative battery terminal???
Old 03-04-2015, 01:36 AM   #15
Alobar
Oddometer: 51
Has anyone worked out the current draw when switched off? I don't have a battery tender and am returning from two weeks leave (without bike) and am anticipating an easy start. I will let you know .....
Alobar is offline   Reply With Quote
Times are GMT -7.   It's 05:26 PM.
