Old 06-29-2014, 12:43 AM   #1
storx OP
Oddometer: 5
KTM 07 450exc: Difficulty finding Nuetral
Hello All,
I recently purchased an 2007 KTM 450exc and since i bought it the neutral has been terribly difficult to find.. i can hardly find it off the bike with my hand at times for a few minutes.. but the original owner said it was like this from the day he bought it from the KTM dealer.. it has always gave him neutral issues. I am curious to know if this may be an issue?? I find that if i shut it off at a light and go to start it while in first still since i couldn't find neutral.. it will lightly move forward like its dragging the clutch just so slightly during start-up at times.. making me worried that i am putting adverse wear on the clutch from all of the first gear starting..
storx is offline   Reply With Quote
Old 06-29-2014, 03:01 AM   #2
DaveyMac
AARP Trail Rider
DaveyMac's Avatar
Oddometer: 174
I just bought a 05 525 EXC, with a bought 2,000 mi on it.
Same issue with it running. Motor off, No problem.
I just think its nature of the beast.
I sure those who Know better will chime in.
08 R1200GS
05 KTM 525exc
GS 911 pro
DaveyMac is offline   Reply With Quote
Old 06-29-2014, 04:24 AM   #3
MashEmOut
Oddometer: 3
'07 525exc. Same thing. Seems like once you come to a stop, releasing the brakes and roll back just a wee bit, releasing the tension on the chain/transmission. Hard to do on a hill but it helps finding neutral.
MashEmOut is offline   Reply With Quote
Old 06-29-2014, 04:35 AM   #4
davesupreme
grand poobah
Oddometer: 1,557
the KTM dirt bike engines don't have a 2nd gear lockout like alotta big bike engines/transmissions have .....
it's pretty much the nature of the beast.... using good motorcycle oil helps some....
you'll see if you hit neutral just as your rolling to a stop, it's alot easier.....
davesupreme is offline   Reply With Quote
Old 06-29-2014, 04:37 AM   #5
nevermind
sLOW Rider
nevermind's Avatar
Oddometer: 3,019
Originally Posted by storx View Post
Hello All,
They all do that. Very very normal... BTW, that is exactly how I find neutral. Get off the bike and I rest a gloved hand against the stator cover and gently pull up on the gear selector. After you get used to it, after many, many hours on the bike, you will be able to find it with your toe when the bike is off.
I can only find neutral while the bike is running when I do not want it!
nevermind is offline   Reply With Quote
Old 06-29-2014, 04:41 AM   #6
nevermind
sLOW Rider
nevermind's Avatar
Oddometer: 3,019
Originally Posted by davesupreme View Post
look to hit neutral just as your rolling to a stop, it's alot easier.....
this too...
Old 06-29-2014, 05:08 AM   #7
RBrider
Oddometer: 328
+ 1 to all of above. Plated '06 450 EXC.
RB
RBrider is offline   Reply With Quote
Old 06-29-2014, 05:55 AM   #8
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,127
2014s are the same way. KTM doesn't use a very strong neutral detent so it'd hard to find it stopped.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 06-29-2014, 06:50 AM   #9
VxZeroKnots
VxZeroKnots's Avatar
Oddometer: 2,805
I never have trouble finding it about 1/4 of the way up a gnarly climb when I want to drop from 2nd to 1st.
I say we take off and nuke the entire site from orbit. It's the only way to be sure
No bike does everything perfectly. In fact, no bike does anything until someone gets on it to ride.
VxZeroKnots is online now   Reply With Quote
Old 06-29-2014, 07:28 AM   #10
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,696
ya that. i like to think of it as a "feature". it's the false neutral eliminator
none of us is as dumb as all of us
clapped_r6 is online now   Reply With Quote
Old 06-29-2014, 07:34 AM   #11
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,854
Tap it into 2nd gear,then give it a slight tap down,once you get the feel it will go to neutral.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Times are GMT -7.   It's 02:18 PM.
