Old 06-30-2014, 06:02 PM   #16
txbear55
Oddometer: 265
Mines like butta, esp. compared to prior HD and BMW! 2011 990 Dakar
txbear55 is online now   Reply With Quote
Old 06-30-2014, 06:11 PM   #17
Tomah
Riding the Northeast
Tomah's Avatar
Oddometer: 204
sherlock shift
I've got an '11 with many thousand miles of dirt, gravel and tarmac. During break-in, I managed to find that "phantom neutral" between 4 and 5 (or was it 5 and 6) twice but other than that, it shifts just like I think it should. Have run everything from Motul to Mobile1 with no noticeable change to the shifting.
I've been riding many steeds over a few decades (mostly dirt) and find that this one shifts quite well ... at least I am ecstatically happy with it ;)
Hope you find the issue.
TOMAH
KTM 990 Adventure-R
Tomah is offline   Reply With Quote
Old 06-30-2014, 06:25 PM   #18
OrangeDevil37
OrangeDevil37's Avatar
Oddometer: 357
i have been running the motordeath oil (motorex) and the bike shifts like hot butter. its crazy how smooth it is. sometimes i wonder if i shifted at all its so smooth. i would check your clutch out and everything connected to it.
2013 990 adventure baja
2009 250sx
2008 690 Duke
2006 250sx-f
OrangeDevil37 is offline   Reply With Quote
Old 06-30-2014, 06:39 PM   #19
windblown101
Oddometer: 877
My '13 990 SMT was a bit rough shifting at first. Like the poster above my issue was an occasional false neutral between either 4&5th or 5&6th.
It may need a bit more thrashing yet to get things smoothed out however what you're describing sounds a bit different than normal break-in woes to me.
Do you know anyone else that rides that you trust to ride the bike and offer a second opinion?
windblown101 is offline   Reply With Quote
Old 06-30-2014, 06:43 PM   #20
Maoule
Maoule's Avatar
Oddometer: 493
I've noticed smoother shifting, especially upshifting, not completely closing the throttle.
Maoule is online now   Reply With Quote
Old 06-30-2014, 11:23 PM   #21
SierraJeep
It's toast
SierraJeep's Avatar
Oddometer: 630
I've got almost 32,000 miles on mine now. I have found that as my oil get old (or slightly low) the shifting gets quite noticeably more notchy when up-shifting and also more difficult to drop back into first from second (without resting in neutral). After an oil change, then it become smooth again. So make sure your oil level isn't too low (like below the dip stick or just at the very bottom).
Lately (and I've just changed my oil) I have found it is getting more notchy and I think it may be time to start re-thinking the clutch system. My clutch system is all stock (2010 model).
Tod
2010 KTM 990 Adventure
2010 KTM 450 EXC
SierraJeep is offline   Reply With Quote
Old 07-01-2014, 08:20 AM   #22
Alex_RO
Wanderer
Alex_RO's Avatar
Oddometer: 206
Chain too tight?
Mine gets a bit rougher when the chain's too tight. After it loosens back up, shifting is very smooth.
2007 Adv 990
Alex_RO is offline   Reply With Quote
Old 07-01-2014, 08:43 AM   #23
JohnnyWaffles
Oddometer: 239
My '13 has 1200 or so miles on it and even sat for a year. Shifts very smooth.
I read an article recently describing the 990A as having one of the smoothest shifting transmissions on adventure bikes. Hopefully you can get yours resolved with some of the advice given
2013 KTM 990 Adventure Baja Edition
Originally Posted by Beefeater Steve
The KTM is the kind of bike you take behind the middle school and get pregnant. It's the kind of bike that, from the moment you light the fire, you know is downright nasty and makes you want to meet in the Burger King bathroom and lick its butthole.
JohnnyWaffles is offline   Reply With Quote
Old 07-01-2014, 09:17 AM   #24
ADVill
Oddometer: 609
2007 Adv 990
Was going to mention that. Very common to run chains too tight on bikes with suspension travel. Chain tightens as rear suspension gets used up.
'08 990 Adventure Orange of course
'00 520 EXC
'14 500 XCW
ADVill is offline   Reply With Quote
Old 07-01-2014, 09:48 AM   #25
EastSideSM
Isn't that dangerous?
Oddometer: 1,490
Originally Posted by jimilivz View Post
So I've had my 13 990a over a year now, 3700 city miles. Am I the only one who hates the tranny on this bike? The ratios are fine, but it just is the worst shifting bike I've ever ridden. Almost impossible to keep from going into to neutral from 1-2, mainly when the engine is warm to hot. Extremely notchy feel. Downshifts are difficult unless I partially release the clutch lever. And it occasionally slips out of second under acceleration.
Dealer says all is fine. Has had the Motorex full synth oil since new. Has KTM improved this on the 1190?
Just a thought, but maybe make sure your shifter is getting loose. That has happened to me and will cause all kinds of weird things to happen including missed shifts etc. Just reach down and if there is any play back and forth with your shift4r, it needs to be tightened up. I would put a little locktite on there to keep it from loosening if you find it has done so.
EastSideSM: '06 950SM Black
EastSideSM is offline   Reply With Quote
Old 07-01-2014, 09:53 AM   #26
Pistolero
W. F. O.
Pistolero's Avatar
Oddometer: 712
Pistolero is offline   Reply With Quote
Old 07-01-2014, 10:43 AM   #27
rattis
rattis's Avatar
Oddometer: 1,168
I've got a 990 2007 with 35000 miles and it shifts like a dream.
sure beats the hell out the BMW but then again about the frontbrakes it's the other way around.
I wish I had bought a GSA a long time ago
and now I drink Orange Crush as well, double up now, a 990Adv and a 950 SER
rattis is offline   Reply With Quote
Old 07-01-2014, 11:40 AM   #28
Questor
More Undestructable
Questor's Avatar
Oddometer: 4,156
Originally Posted by Orangecicle View Post
Go ride a BMW 1150/1200 and then come back and talk to us about how great your KTM shifts.
I had a BMW.
Shifting was akin to the sound of jamming a metal fork in a running blender.
Q~
Old 07-01-2014, 12:42 PM   #29
OzzyVee
Oddometer: 3
Yep. Loose shift lever will cause all kind of weird in shifting.
It also could be poorly aligned shift shaft. That happened to me. Gearbox jammed to 6th gear occasionally and it was hard to find neutral. Also once it feel like neutral was between 2nd and 3rd gear.
And if shift lever had been hitted to ground, rock etc. small bushings between shift forks and shift drum could jammed.
OzzyVee is offline   Reply With Quote
Old 07-02-2014, 09:38 AM   #30
DavidQ
We Don't Rent Pigs
Oddometer: 2,038
It mad at you for making it spend it's life in the city!!!
Seriously, check the clutch oil jet.
2001 1150GS / Ural Hack
2011 990 Adv R
Colorado / Utah 2010
Colorado / Utah 2011
NM, CO, UT, AZ 2012
DavidQ is online now   Reply With Quote
Times are GMT -7.   It's 05:28 PM.
