Old 06-30-2014, 10:07 PM   #1
Nailhead OP
Free at last!
Nailhead's Avatar
Oddometer: 6,317
Question What to Clean My Brakes With...
The last ride I took was a mudfest, and it left some sort of residue on my front brakes that make them almost useless: it's like they're soaking wet all the time.
What would clean rotors & pads, and restore them to their pre-mud effectiveness? Solvent? ScotchBrite?
i'd post a photo, but I won't see the bike until Thursday.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 06-30-2014, 10:43 PM   #2
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,177
Well, um, I'd start with brake cleaning solvent. Get the stuff in the red can. You can tell if it's the good stuff by the label on the back: "known by Kalifornia to give rats cancer"
Soak the brake pads with it and rough them up with 80 grit. Heat them with a good heat gun, cool and repeat. Get them good and hot. If there's oil in them you'll see it bubble out. I've recovered a few pads that were oiled by leaking fork seals. Doesn't work all the time. Do it well ventilated because heating clorinated solvents makes phosgene gas, called Mustard Gas in WW One.
Rough up the disks with 80 grit and brake cleaner. Don't use power tools, you may grind a bad spot.
Ride it and do some repeated stops. Don't let it get real hot. You are coating the disks with brake material. It may take 10 or more stops for it to come back. About 100 miles to get to max. If it doesn't work, get new pads and rough the disks again.
"Son, you can't do both"
Old 06-30-2014, 11:50 PM   #3
Nailhead OP
Free at last!
Nailhead's Avatar
Oddometer: 6,317
Thanks, Zube, but it's not an oil-based problem, so do you still think I need to go through the heating process?
I like the 80-grit idea: gets things done.
-Chris
Old 07-01-2014, 12:32 AM   #4
ADVill
Oddometer: 611
Maybe it's your brake.... Fluid. Mushy feeling? Pads don't get damp. I've run hours of ISDE Qualifier in the rain. They don't get wet...
'08 990 Adventure Orange of course
'00 520 EXC
'14 500 XCW
ADVill is offline   Reply With Quote
Old 07-01-2014, 02:32 AM   #5
Nailhead OP
Free at last!
Nailhead's Avatar
Oddometer: 6,317
No, they feel same as ever, just ineffective. I just need an idea of how to remove the weird hardened masonry glaze from rotors & pads (see "residue" above).
I wish I had a pic-- it really is hard to describe.
Zuber's suggestion was the seed of an idea: 80-grit used flat on a metal plate to clean pads, then a Very Fine ScotchBrite to polish rotors. Any bad side to this I might not be seeing?
-Chris
Old 07-01-2014, 06:36 AM   #6
uk_mouse
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,481
I just use a wire brush on the pads.
"When compared to other motorists attempting to escape a zombie outbreak, dirt bike riders have a 23-to-1 survival rate." - The Zombie Survival Guide by Max Brooks
uk_mouse is offline   Reply With Quote
Old 07-02-2014, 03:03 AM   #7
Nailhead OP
Free at last!
Nailhead's Avatar
Oddometer: 6,317
Noted. I'll try almost anything at this point. I like brakes.
-Chris
Old 07-02-2014, 04:56 AM   #8
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 1,093
I had a MK1 Lemans Guzzi once. Rode it to Philip Island to see Superbikes. At South Australian border it started to rain. By the time we got to PI the rain was sidways and they canx the second race. Meeting was a wash out.
I had no brakes untill we left Victoria and got a good day of no rain.
So some pads can get effected by water. (this had no mud)
No amount of applying brakes while moving changed things.
Wife was not impressed years later when I told her !!!
990 Adv 06, Aprilia Tuono 03 Racing gen 1
rossguzzi is offline   Reply With Quote
Old 07-02-2014, 05:09 AM   #9
stupot
stupot's Avatar
Oddometer: 124
wd40
stupot is offline   Reply With Quote
Old 07-03-2014, 02:16 AM   #10
Nailhead OP
Free at last!
Nailhead's Avatar
Oddometer: 6,317
Originally Posted by stupot View Post
wd40
We'll take turns-- you're first.
I've got a long ride planned for Saturday, and I'm not going to use those wheels (knobbies). I've got new rotors for the set I'll run (Mefos) so I'll just sand the pads with 80-grit & be on my way. That way I can procrastinate on the pottery-glazed rotors, which is really how I deal with most things.
-Chris
Nailhead screwed with this post 07-03-2014 at 02:21 AM
Old 07-03-2014, 05:19 PM   #11
woodchuckexc
Oddometer: 801
Use some 220grit sand paper. Use an orbital sander on rotors and place the paper on a flat surface and hand sand the pads. Id also flush the fluid. I prefer having fresh. Its cheap and easy.
woodchuckexc is offline   Reply With Quote
Old 07-03-2014, 05:52 PM   #12
kag
Wander Lust
kag's Avatar
Oddometer: 1,791
In the time it takes you to mess around cleaning pads.....other than just hosing them off with high pressure water.....you could change the pads.
Cheap and easy
“Always drink upstream from the herd”
2007 Yamaha TW 200 / 2008 Buell Ulysses
2013 Triumph Tiger 800r / 2014 KTM 1190 EDS
kag is offline   Reply With Quote
Old 07-03-2014, 06:14 PM   #13
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 820
Have you bought pads for your KTM already?? You might remove the cheap bit,, easy YES. Unless someone knows a secret source for the sintered brembos for me? I just started shopping,, and so far not finding a brand pad for much under 100 for the front..
Freedom is a delicate thing.
More easily lost than gained.
pdxmotorhead is offline   Reply With Quote
Old 07-03-2014, 06:31 PM   #14
kag
Wander Lust
kag's Avatar
Oddometer: 1,791
I do not buy KTM nor Brembos brand.......have a look on ebay
Old 07-03-2014, 07:03 PM   #15
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,579
HH...anything.
2013 KTM 690R Enduro
Chuckracer is online now   Reply With Quote
Times are GMT -7.   It's 05:56 PM.
