Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 07-07-2014, 05:39 AM   #1
alongat OP
alongat's Avatar
Oddometer: 1,114
1190 - spots on the garage floor???
Just took delivery if my new 1190 standard on Saturday. Rode it Saturday and yesterday - put the bike away to sleep last night, went to visit it this morning and discovered two spots under the bike. I can't really tell what they are (no obvious smell of oil or gas, etc) and I would describe their location as about under the fuel tank petcocks despite the bike being on its side stand, not the centre stand both spots are equal in size / amount of this mysterious liquid. I pushed the bike forward two feet and went away, came back thirty minutes later and two new spots seem to have appeared. I'll take a much closer look under the bike for anything obvious but can you please share if this happened to anyone else as I've not seen it documented here in orange crush anywhere.
Bike kicks ass apart from this (and the heat under the seat) :)
Thanks in advance
Toronto, Canada
KTM 1190 ADV, KTM 530 EXC
Gone: Ducati 999R, KTM 530EXC, KTM 990ADV-R, KTM 950ADV, KTM 690, KTM 640ADV, kTM RC8R, Ducati 996S, Yamaha R1
And how can this be? For he is the Kwisatz Haderach!
alongat is offline   Reply With Quote
Old 07-07-2014, 05:53 AM   #2
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,402
Three people I know
Including myself had to have the gasket replaced on the stator cover. Look on the left side of the bike down low on the bike
Just a heads up
ebrew is offline   Reply With Quote
Old 07-07-2014, 06:31 AM   #3
georgian cliff
Oddometer: 8
I have notice some leakage from the breather hoses that come down on the left side of the engine. It was especially noticeable when I was pushing the bike hard in very hot weather.
One line is for fuel - the others are??
georgian cliff is offline   Reply With Quote
Old 07-07-2014, 06:36 AM   #4
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,402
Lines
Air box drain and coolant I believe
Old 07-07-2014, 06:59 AM   #5
alongat OP
alongat's Avatar
Oddometer: 1,114
Don't think the spots are fuel or oil - no real scent to the liquid on the floor. Coolant perhaps? Hmm...
Toronto, Canada
Old 07-07-2014, 07:05 AM   #6
Knackers
Polishing Turds
Knackers's Avatar
Location: Drinking Vic, Qld & NSW Sewerage, Adelaide SA
Oddometer: 4,803
http://advrider.com/forums/showthread.php?t=992043
I rest my case
How the hell did you get all this together?
It just happened, Max, you know?
A p-p-p-p-piece from here and a p-p-p-piece from there.
Knackers is offline   Reply With Quote
Old 07-07-2014, 07:17 AM   #7
alongat OP
alongat's Avatar
Oddometer: 1,114
Which case - that the 1190 should be spun out to its own sub-forum in the same way the BMW forums split air cooled vs. liquid cooled or that the 1190 is a piece of shit in your mind?
Either way, it doesn't help me diagnose my new bike experience... :)
Originally Posted by Knackers View Post
Toronto, Canada
Old 07-07-2014, 07:36 AM   #8
Knackers
Polishing Turds
Knackers's Avatar
Oddometer: 4,803
Mate,
It is a leak. If you were near me I'd ride over and help you. I'm serious.
But I think with each bikes individual peculiarities the forum is getting diluted.
After checking all oil and coolant pipes if you find that the cases or another cover was leaking that would be worth reporting. Identifying an tightening up a loose pipe isn't hard.
Old 07-07-2014, 07:53 AM   #9
Black Hills
Oddometer: 1,181
check the top radiator hose (left side) mine was loose and would leak a little bit.
Black Hills is offline   Reply With Quote
Old 07-07-2014, 12:17 PM   #10
Todd-Squad
See Ya, Bye.
Todd-Squad's Avatar
Oddometer: 773
Did you top off the fuel recently?
If the tank was full and you had it parked on the side stand, I think it would be quite common for the tank overflow line to drip a bit. Mine will do that from time to time.
A ride you say? When and Where?
My Favorite Pics
Todd-Squad is offline   Reply With Quote
Old 07-07-2014, 01:10 PM   #11
NoSpam
Oddometer: 168
Hey Alongat - did you get a Unifilter installed? If so, the intake "socks" are so heavily oiled, they can actually drip down the sides of the radiator housing and make a small pool of non-smelling, slightly viscous fluid. If you take off the front/side panels, you can inspect the intake area easily and (if nothing else) eliminate that as the source of the fluid.
Good luck!
NoSpam is offline   Reply With Quote
Old 07-07-2014, 01:11 PM   #12
DirtJack
DirtJack's Avatar
Oddometer: 1,521
The one which is plugged with a bolt is the air box drain. Another drains the catch area outside the filler neck. It should drain only when you overflow the filler neck. The third line is a tank breather line.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 07-07-2014, 03:47 PM   #13
alongat OP
alongat's Avatar
Oddometer: 1,114
It's definitely coolant - went for a ride today, parked the bike on its side stand in my garage and the same spots appeared. Tastes sweet - that says coolant to me...
Toronto, Canada
Old 07-07-2014, 11:39 PM   #14
wizze
Wizze = Wise
wizze's Avatar
Oddometer: 1,094
Rode a demo bike that has been used for what it was designed. Stopped to get some fuel after a lengthy demo ride and a good size puddle of coolant. Good size = 3" diameter
so..... wazzup wit dat
2009 BMW F800GS
2009 Yamaha FZ-1 Retro
2012 KTM 500 EXC
2005 BMW R1200RT
Is that it?
wizze is offline   Reply With Quote
Old 07-08-2014, 04:52 AM   #15
alongat OP
alongat's Avatar
Oddometer: 1,114
Finally crawled under and had a close look - seems that whoever in production or prep was responsible for assembling the radiator hoses neglected to use the correct tool on the lower rad hose - the 5.5mm hose clamp nut seems to be nicely "rounded" by someone tightening it with the wrong tool or slipping. The hose clamp appears to be under tightened and of course now I have no way of tightening it as the bolt head is inconveniently stripped - needle-nose vice grips perhaps...Anyhow, this makes me nervous enough to want to check all other hose clamps, etc.
Toronto, Canada
Times are GMT -7.   It's 12:35 PM.
