Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 07-04-2014, 01:38 PM   #1
breakfastbuddy OP
Oddometer: 33
i cant start my 1190R
do some of you have some tips ? the starter goes around , and i have charged up the battery , even used cabels from a car , its no fault messages , i started it up , but i forgot to take of the alarm from the brake disk , then stopped the bike with dead switch , tried to start it again and now its not starting , i have not tried to start it by going down a hill .
breakfastbuddy is offline   Reply With Quote
Old 07-04-2014, 02:17 PM   #2
2wdrift
Oddometer: 107
re
Mileage and year?
Mine did that when the airbox issue let dust through. But it could be many things.
(yeah I know all problems are airbox related, even the hot seat is caused by the faulty airbox )
A stupid question but is the kill switch in the on position?
2wdrift is offline   Reply With Quote
Old 07-04-2014, 02:58 PM   #3
breakfastbuddy OP
Oddometer: 33
1190 R wont start
2013 7500 km have never had a problem with it before yes the kill switch is on , the starter will not turn when its off , its not the air filter , had a check for 1 months ago
Old 07-05-2014, 04:48 AM   #4
skogsharald
Oddometer: 4
I had problems with starting when the temperatures were under 5 degrees c.
Got advice from the dealer to open the throttle by 2-3 mm when starting.
Never got any problems after that.
Also have a 2011 Ducati Diavel with the same problems. There I had to replace spark plugs before I got it started...
Tor,
'14 KTM 1190 R
skogsharald is offline   Reply With Quote
Old 07-05-2014, 05:22 AM   #5
breakfastbuddy OP
Oddometer: 33
1190 R wont start
well its not Cold here , 20 celsius , so thats not it , i will bring it to the dealer on Monday ,
Old 07-05-2014, 05:30 AM   #6
_Magoo_
master of disaster....
_Magoo_'s Avatar
Oddometer: 5,727
check the flux capacitor.....
-Baja survivor NMOHVA/COHVCO/BRC/AMA/USA-ALL
I'm not a Gynecologist... But I'll have a Look...
2007 Suzuki WeeStrom/2006 KTM450EXC/2001 Honda XR650L/2001 Sherco 290
_Magoo_ is offline   Reply With Quote
Old 07-05-2014, 02:31 PM   #7
DirtJack
DirtJack's Avatar
Oddometer: 1,607
There is a replacement set of starter cables for 1190s manufactured before 22 Nov 2013. This includes early 2014 1190s. Your dealer can verify whether the replacement applies to your VIN.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 07-06-2014, 01:24 AM   #8
breakfastbuddy OP
Oddometer: 33
cant start 1190R
the cabels have been replaced at first service
Old 07-06-2014, 09:10 AM   #9
KawiPhil
KawiPhil's Avatar
Oddometer: 21
Check fuel pump connector. Are the crossover line valves open?
14 KTM 1190 ADV R, 10 KLR 650, 09 Ural Gear Up, 81 KZ750, 78 KZ650B, 79 KZ650C, 74 Yamaha DT360
KawiPhil is offline   Reply With Quote
Old 07-07-2014, 03:36 AM   #10
breakfastbuddy OP
Oddometer: 33
cant steart 1190R
well today before i was going to deliver my bike to the dealer , tried one more time myself , i charged up the battery , and took the bike down a hill, and put it into 3rd gear and then it turned around and i heard it was comming back to live , so my thoughts is that the starter takes to much amp and that stops the ignition , a bigger battery would probely solve the problem ,
Old 07-07-2014, 06:07 AM   #11
Knackers
Polishing Turds
Knackers's Avatar
Location: Drinking Vic, Qld & NSW Sewerage, Adelaide SA
Oddometer: 4,840
http://advrider.com/forums/showthread.php?t=992043
I rest my case
How the hell did you get all this together?
It just happened, Max, you know?
A p-p-p-p-piece from here and a p-p-p-piece from there.
Knackers is offline   Reply With Quote
Times are GMT -7.   It's 12:54 PM.
