Old 07-04-2014, 06:01 PM   #1
TheRog OP
Dirtylittle funhaver
Oddometer: 75
2into 1
On a 07 990 adv. s, can I put a block off plate on the 3 bolt muffler flange where the silencer goes, thus converting it from a 2 to 2 into a 2 into one, or will I be ridiculed for coming up with this thought.
I would like to save the weight and use that area for a tool tube made out of like 3 or4 inch PVC pipe.
I noticed the crossover tube by the shock, so?
I know it may mess with the tuning, like maybe make it richer, but it's already too lean.
TheRog screwed with this post 07-04-2014 at 06:08 PM
TheRog is offline   Reply With Quote
Old 07-04-2014, 07:28 PM   #2
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,331
Ridicule...sorry mate.
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 07-04-2014, 08:07 PM   #3
Dan950ser
NW Shredder
Oddometer: 485
Or you could just plug a muffler. Sorry couldn't help myself.
2015 KTM 690 Enduro R, 2007 KTM 990 SuperDuperEnduroR For Sale http://www.advrider.com/forums/showthread.php?t=1046431, 2014 KTM 250 XC-W
Dan950ser is offline   Reply With Quote
Old 07-04-2014, 11:11 PM   #4
TheRog OP
Oddometer: 75
Ridicule
Fine. But they make two into one systems right.
So what if I have the two pipes merged into one there by the balance tube by a tig welder you know a proper mod.
Still ridicule?
Old 07-05-2014, 05:32 AM   #5
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,331
It should look just like this.
Everybody I know who has one made their own. Now yer rollin!
Old 07-05-2014, 05:35 AM   #6
Sumi
Sumi's Avatar
Oddometer: 1,799
Why not try it?
Old 07-05-2014, 12:03 PM   #7
Dan950ser
NW Shredder
Oddometer: 485
Okay enough ridacule. You can have a tig welder make a 2-1 collector out of your stock peice or there is an exchange program by cj designs as mentioned in the other 2-1 thread going right now. That's the one I have on my bike as well as his aluminum liquid holding tank. Hope this helps. If you just blocked off the header it would really affect performance of the engine. If you have some one make one for you make sure they do a nice job of cutting and blending in the header for an unobstructed nice flowing pipe.
Old 07-05-2014, 06:54 PM   #8
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,336
Frankly,,,,, I think mine flows better.....
Super Enduro
Adventure....
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 07-05-2014, 07:00 PM   #9
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,862
The cross over you are referring too would be too restrictive, look at the ones that are built and you will see what I mean.
You would be SERIOUSLY choking back your bike.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 07-05-2014, 10:04 PM   #10
TheRog OP
Oddometer: 75
nice
You did that yourself. It's perfect. so that one eliminates the right side can and flows out the left, yes? Fine bit of fab there.
Super Enduro
Adventure....
Old 07-06-2014, 10:05 AM   #11
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,336
Correct..... left side merge. I can't take credit for the welding, only the fitting. I have a guy that does the TIG work that is top notch. He does high end custom cars and every time I bring one of these in for welding asks if I want a job fabbing custom headers. I use a stainless steel 'U" bend for the merge section. Really not that hard,,,, just take your time.
Old 07-06-2014, 02:43 PM   #12
JoeMongo
¿Por dónde?
JoeMongo's Avatar
Oddometer: 514
Thumb
I considered fitting and welding my own, but realized that I would probably just burn holes in the tubing at the same time as I failed to get sufficient penetration. Yup, I have no false confidence in my light gauge welding skills. I should only weld mild steel that is at least 1/4 inch thick. I did once repair a BMW exhaust pipe, and it held for 30K miles or so before I sold the bike, but this modification scope is a whole different order of magnitude to that small repair job.
Knowing that I'd probably ruin my H-pipe, I sent it to CJ for him to get his welding dood to make me a nice 2-1 out of it. He did a excellent job fitting and welding it, and it was back in the mail to me the day after it was delivered to him. That is what I call outstanding customer service. I believe that the price was very reasonable, and am a happy customer.
J.
'08 990 ADV, '03 DR-Z400S
Anything worth doing, is worth overdoing.
JoeMongo is offline   Reply With Quote
Times are GMT -7.   It's 11:49 PM.
