Old 07-04-2014, 06:16 PM   #1
prince OP
prince's Avatar
Oddometer: 96
weird throttle response
it seems that my engine isn't responding to my throttle right away around the 4500/5000 rpm, it's a bit "jerky".
i tightened the chain and i do have a loose graphite ring around one pipe but i can't think that that could be the cause. my chain and sprockets have about 3500 miles on them so i don't know what it could be. The chain was an expensive one and its in good condition, i do have a G2 throttle.
It is something i' ve noticed recently, in the last 1000 miles.
Any ideas, suggestions?
thanks in advance
07 KTM 990 adv
06 Triumph Scrambler
04 1150 GSA (sold)
02 1150 GS ( crashed and stolen)
00 750 Ducati monster ( sold)
prince is offline   Reply With Quote
Old 07-04-2014, 07:19 PM   #2
Racer111v
Racer111v's Avatar
Oddometer: 812
An exhaust leak can mess with the O2 readings at the sensors. I would fix that first.
2004 KTM 950 ADV ...............................1979 Suzuki RM400 VMX Race bike
2006 DR-Z400E plated........................... 2001 Ducati ST2 944
2001 YZ250N 2T plated.......................... 1986 Yamaha FJ1200
Racer111v is offline   Reply With Quote
Old 07-04-2014, 11:24 PM   #3
TheRog
Dirtylittle funhaver
Oddometer: 75
Snatchy throttle
I have a 07. 990 adv. and they seem to have the freaky deaky throttle response.
The transition from off throttle decel to on throttle accel is a big jerky affair..
Riding along at steady cruise throttle has a bad flat spot when you role it on to accel.
It's not the chain. It's Ktm's inability to sort a proper fuel map for a bike that's 7 bloody years old. Disgraceful if you ask me.
The dealers don't give a shit.
About the only thing that's worked is a custom map from a pro tuner with a Dino and a exhaust sniffer.
TheRog is offline   Reply With Quote
Old 07-04-2014, 11:26 PM   #4
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,091
I would guess you need to check the TPS sensor or other adjustments, valve clearance, throttle body balance, etc.
"Son, you can't do both"
Zuber is online now   Reply With Quote
Old 07-05-2014, 02:25 AM   #5
ADVill
Oddometer: 609
I just adjusted the valves on my '08. I can't believe it made that much difference in how smooth the bikes is. I still think it's something else but I did nothing else.
'08 990 Adventure Orange of course
'00 520 EXC
'14 500 XCW
ADVill is offline   Reply With Quote
Old 07-05-2014, 07:41 AM   #6
prince OP
prince's Avatar
Oddometer: 96
the valves were adjusted 3000 miles ago, so i'll start with that ring and go from there. Also after i switched to FMF can i only did the 30 mns "running adjustment" on the bike, it hasn't been properly tuned with a map. I guess that will be my second thing to do ( not looking forward to it since there in an extensive thread on it which means its unresolved).
07 KTM 990 adv
04 1150 GSA (sold)
Old 07-05-2014, 08:31 AM   #7
Bighat
Oddometer: 39
Check with the dealer, there has been a map update but I'm not sure when it was issued....my 07 runs great all stock...
Bighat is offline   Reply With Quote
Old 07-05-2014, 10:12 AM   #8
crashmaster
ow, my balls!
crashmaster's Avatar
Oddometer: 5,291
Jerky throttle and a flat spot around 4500 rpm? My 07 has been that way for 70,000 miles.
Riding the Americas: No Fumar Español
_____________________________________________
crashmaster screwed with this post 07-05-2014 at 10:26 AM
crashmaster is offline   Reply With Quote
Old 08-08-2014, 04:55 PM   #9
prince OP
prince's Avatar
Oddometer: 96
ok so i took my bike to my mechanic, inside line moto in OC, he tries the bike and then the bike dies. It turns out it's a broken spring retainer.and it's a complete engine rebuilt. around $4200. i am at a loss here, my mechanic told me he never saw this before, does anyone? see attached photo of the culprit.
07 KTM 990 adv
04 1150 GSA (sold)
Old 08-08-2014, 07:30 PM   #10
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,407
Why a complete rebuild? Did the valve drop on the piston? Not sure why that would require a complete rebuild.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Times are GMT -7.   It's 09:12 PM.
