Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 07-06-2014, 12:30 PM   #16
kegonlegs
Oddometer: 41
Dont know much about this issue and dont like the problem as i own a 990.But can a tube be installed on the 1190 wheels.In this months Cycle world Travel and Adventure they dent the front rim and have this issue. Nothing a crescent wrench and little silicone wouldnt seal is there reply.wow,i have dented the rim so hard on my 990 that i could see the tube.Would be scared riding one of these in some out there hairy places
kegonlegs is offline   Reply With Quote
Old 07-06-2014, 02:27 PM   #17
Pork Butt
Save the USA
Pork Butt's Avatar
Oddometer: 67,354
Chances are were are all going to have issues with the stupid "bladder" they use to seal the spoke wheels. My dealer specifically has told me they have had problems with this set up and not to slime the things as that eats the TPS sensor.
I would rather have cast ism anyway I don't plan of taking mine off road. I am trying to source some that will fit.
PB
I'm a piston farmer .....
Pork Butt is offline   Reply With Quote
Old 07-07-2014, 06:08 AM   #18
Knackers
Polishing Turds
Knackers's Avatar
Location: Drinking Vic, Qld & NSW Sewerage, Adelaide SA
Oddometer: 4,820
http://advrider.com/forums/showthread.php?t=992043
I rest my case
How the hell did you get all this together?
It just happened, Max, you know?
A p-p-p-p-piece from here and a p-p-p-piece from there.
Knackers is offline   Reply With Quote
Old 07-07-2014, 11:24 AM   #19
Todd-Squad
See Ya, Bye.
Todd-Squad's Avatar
Oddometer: 774
Originally Posted by madatter View Post
Started up the bike yesterday and the magic low tire pressure alarm was in.
Down to 10lbs from day before.
Topped it up and went for a ride.
When in motion tire held pressure....every stop tho it would lose a couple of psi.
Ive checked for punctures,snooped around and can find nothing.
I've never had tubeless tire....researching a bit it seems KTM has had a bit of an issue with the spoke sealing band.
Wondering just how common this has been...
I've been switching tires fairly regularly between knobbies and the stock tires. I never had a leak with the stock tires, but as soon as I went to knobbies, I started losing pressure. The key is to keep the tire pressure above 35psi. The way the inner spoke seal works, is it needs that much pressure to keep the seal in place, otherwise, it can lose pressure pretty fast. Once I learned this little trick I haven't had any more pressure issues.
A ride you say? When and Where?
My Favorite Pics
Todd-Squad is offline   Reply With Quote
Old 07-07-2014, 11:39 AM   #20
scudrunner82
combustion addict
scudrunner82's Avatar
Oddometer: 2,534
PB
A much easier solution would be to install tubes. Thats the great thing about the KTM setup, got a leak? install tubes.
Cast wheels suck on off road bikes.
Hungry Tenere TripTeam Ghetto Does a Hot Lap of America
350, 450, 848, 900, 1190r
My Youtube channel----- https://www.youtube.com/channel/UCXo...kdER0Y5QfoE9gQ
scudrunner82 is online now   Reply With Quote
Old 07-08-2014, 02:31 PM   #21
madatter OP
madatter's Avatar
Oddometer: 51
Dealer is replacing sealing band no questions asked by KTM.
He's a bit hard edged and doesn't mince words with manufacturer when there are problems...or with people when they are a bit whiny!
Be ready in time for days off...
Hoping it's not a continuing saga but we will see.
Once the stock tires are worn a set of TKC 80s will be going on....geeze I hope that doesn't compound the issue.
As far as pressure goes I was always in the 44lb range till the leak started....
2008 KTM 690(sold)
2013 KTM 350EXC
2014 KTM 1190 Adventure
madatter is offline   Reply With Quote
Old 07-08-2014, 04:05 PM   #22
renogeorge
Oddometer: 1,395
There's a lot to be said for tubeless tire. Everyone should have the pleasure of a rear flat out in the boonies--compare repair joy with tube vs plugging tubeless on the bike. I have run Tubliss on my dirt bikes for many years. For repair ease and ability to run lower pressures.
Hope KTM gets their tubless setup sorted out. May be a little learning curve on the rider side for some.....
FWIW
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 07-08-2014, 06:20 PM   #23
kag
Wander Lust
kag's Avatar
Oddometer: 1,719
I had issues also but it started when i took the TKC80 off the rear and put the OEM back on for a 3k trip. I slimed it and 4k miles later still holding air and the sensor still works. I am sure it was the inner seal they use. When the I spoon on the new TKC80 I am sealing the spokes with a little dab of goop on each one under the rubber seal on the inside of the rim.
I would never go back to running tubes in the tires unless I had no other choice.
“Always drink upstream from the herd”
2007 Yamaha TW 200 / 2008 Buell Ulysses
2013 Triumph Tiger 800r / 2014 KTM 1190 EDS
kag is offline   Reply With Quote
Old 07-08-2014, 06:28 PM   #24
renogeorge
Oddometer: 1,395
I run the rear on my 990 with goop on the spoke nipples--no bladder.
FWIW
KTMs--300, 518, 990
Old 07-09-2014, 07:35 AM   #25
Pork Butt
Save the USA
Pork Butt's Avatar
Oddometer: 67,354
I don't intend to ride off road other than the occasional gravel road. I bought the KTM in rather than the Multistrada bc I have a KTM dealer and I had to make several trips out of state to get my Hypermotard warrantied.
great combination 1190 to travel and the Hyper for short rides
PB
Old 07-09-2014, 08:22 AM   #26
scudrunner82
combustion addict
Oddometer: 2,534
PB
Hmmm. That does sound like a nice stable of bikes.
I test rode a Hyper and that thing was a riot.
Old 07-16-2014, 02:35 PM   #27
madatter OP
madatter's Avatar
Oddometer: 51
The saga continues...
Liner replaced and all seemed well....but its leaking again.
Dealer is giving me his rear new rim n tire while they try to figure it out.
This is starting to get annoying.
2008 KTM 690(sold)
2013 KTM 350EXC
Old 07-16-2014, 02:59 PM   #28
PS-RagE
PS-RagE's Avatar
Oddometer: 648
My front leaks but the rim has a couple good flat spots so I'm not too surprised.
I'll be replacing the whole wheel soon and will get this one tended to afterwards.
A. Dale McLean
aka PS-RagE
2007 Beta REV3 270
2012 KTM 350 EXC-F
2014 KTM 1190 Adventure R
PS-RagE is offline   Reply With Quote
Old 07-21-2014, 09:36 PM   #29
madatter OP
madatter's Avatar
Oddometer: 51
Well I picked up something and put a good hole in center of tread of the stock tire.
It's been plugged and is holding air but I have no confidence in it and doing any fast speed so I have ordered the set of TKC 80s instead of just replacing the back stocker.
Should be here in a couple days.
2008 KTM 690(sold)
2013 KTM 350EXC
Old 07-22-2014, 05:15 AM   #30
jj_pt
Oddometer: 47
Originally Posted by NoSpam View Post
Hey Mad - I had the same issue on my front tire - first noticed on the way home from the dealership. I kept adding air until the first service, where spokes were checked and adjusted; no issue since. Good luck with the fix!
I'm also having a leak on the front tyre in one of the rim spokes. It looses around 0,3 BAR every day and I'm just waiting for the next service to fix it.
2013 KTM 1190 Adventure R.
2010 Yamaha XT660Z Ténéré (Sold).
jj_pt is offline   Reply With Quote
Times are GMT -7.   It's 08:27 AM.
