Old 07-12-2014, 04:44 AM   #1
OldDog OP
aka Hugh Jarse
OldDog's Avatar
Oddometer: 4,699
Quick question for the CR500 Guru's
Howdy all, being a Honda CR500 noob I need to ask what is probably a very embarrassing noob question.......
How do I identify the year of manufacture of this engine? I have in my possession a water cooled CR500 motor which is pulled down. Apparently this motor was used in serious dirt sidecar use and I have the expansion chamber to prove that much. The guy I got it off said it was from a 2000 or so model, but I've just been informed that its more likely a 86-89 model?
I'm going to do some nasty, sick "experimental" things with this engine at some stage, so also need to know which if theres a particular model that is considered a "keeper", any weaknesses etc.
Bill
Your time is limited, so don't waste it living someone else's life. - Steve Jobs
Yesterday afternoon I was planning to ride Dakar, this morning I was planning to throw up in my helmet - Boris Mihailovich
Objects in the rear view mirror.....appear to be losing - Me
OldDog is online now   Reply With Quote
Old 07-12-2014, 08:04 AM   #2
anotherguy
anotherguy's Avatar
Oddometer: 6,631
Look here. There's a year code in the VIN. On the engine the number usually starts with 2 or 3 letters. It's in there. Post up the engine number and we'll figure it out.
BTW the 86 had the biggest peak power numbers but is a real beast due to peakyness. And a peaky CR500 is a scary animal.
you don't see luggage racks on a hearse..........act accordingly
Old 07-12-2014, 02:45 PM   #3
Rd650
Rd650's Avatar
Oddometer: 238
Hey Old Dog sent you a PM
Rd650 is offline   Reply With Quote
Old 07-12-2014, 04:03 PM   #4
OldDog OP
aka Hugh Jarse
OldDog's Avatar
Oddometer: 4,699
Hey Roger, email sent! Thanks.
I've had a look at the VIN number on the tag and its PE02E 5502833
Looking at vin number searches this comes up as either an 86-87 model motor or a 96 model motor
To be truthful, I'm just happy to have a CR500 motor, but I will need to know the year for parts and specs so I can work out just what has been done to the engine.
Old 07-12-2014, 05:39 PM   #5
Rd650
Rd650's Avatar
Oddometer: 238
Old Dog
Should be in your email let me know if it does not show
Thanks Roger
Old 07-12-2014, 05:51 PM   #6
OldDog OP
aka Hugh Jarse
OldDog's Avatar
Oddometer: 4,699
Yup it's shown up, Thanks again Roger much appreciated!
Old 07-12-2014, 05:59 PM   #7
Rd650
Rd650's Avatar
Oddometer: 238
No problem Good luck with your project.
Old 07-12-2014, 09:39 PM   #8
OldDog OP
aka Hugh Jarse
OldDog's Avatar
Oddometer: 4,699
Thanks,
So looks like the engine is largely an 87 model with lots of porting and later model side cover / water pump mount. It's .5 mm over bored but seems to have the longer conrod, and yet has the earlier crankcases which are 5 mm shorter.
All very strange, but anyway now I have a bit more of a handle on what I have. Dunno if its any better / worse than the more modern ones but the earlier had more power so for me I'm happy to believe the earlier motor is the better one
Cheers
Times are GMT -7.   It's 07:07 PM.
