Go Back   ADVrider > Riding > Regional forums > Canada
Old 07-13-2014, 10:08 AM   #1
IJM OP
Hinderant Backbenderz
IJM's Avatar
Oddometer: 223
Tire Mounting Help Request Toronto Area
I'm in the process of putting a set of Michelin's on my bike (1200GS) and the front went ok but the back tire doesn't want to play nice.
I've got one side on, but now working on the other side is a pure bastard.
Any advice/tricks on offer? I used to go to DSP for tires but that's not available anymore.
Anyone know of a good place to get tire mounted in the Toronto Area - I'm located in Maple.
Appreciate any assist.
Horizontally opposed, Vertically challenged
IJM is offline   Reply With Quote
Old 07-13-2014, 01:31 PM   #2
rob1313
Still learning
rob1313's Avatar
Oddometer: 4,381
Have you watched any of the online videos on tire mounting? Biggest thing I've found is making sure the opposite edge is in the valley of the wheel. I'm too far to help besides that.
"To live is the rarest thing in the world. Most people exist, that is all." - Oscar Wilde
rob1313 is offline   Reply With Quote
Old 07-13-2014, 02:52 PM   #3
Motoaxe
Doctor of Misfortune
Motoaxe's Avatar
Oddometer: 856
Rosey Toes Motorcycles Inc
131 Wendell Ave
North York, ON M9N3K9
416-241-2523
Cheers!
Ron
Eastern Ontario Adventure Rally 2010
Eastern Ontario Adventure Rally 2011
Dr Cool.....Im missin ya man....
Motoaxe is offline   Reply With Quote
Old 07-14-2014, 03:59 AM   #4
Sunday Rider
Adventurer Wanabe
Sunday Rider's Avatar
Oddometer: 778
The other big mistake is not using enough lube. You have to do that last bit of tire in very small increments, and the lube helps things immensely.
+1 on Rosy Toes. Expect bad humour and he takes cash only.
'97 Honda ST1100
Sunday Rider is offline   Reply With Quote
Old 07-14-2014, 05:19 AM   #5
IJM OP
IJM's Avatar
Oddometer: 223
Thanks folks
I'll definately keep Rosey Toes in mind next time around. I ended up letting it sit in the sun for a few hours and that softened it up enough to get mounted.
Thanks for the feedback.
Old 07-14-2014, 05:20 AM   #6
Pay Dirt
panning the web
Pay Dirt's Avatar
Oddometer: 347
All good tips!, i would add;align the yellow/red dot(if there is one) stamped on the side of the tire with the filler stem , MAY eliminate the need to balance ,leave any balance weights now on the rim in place. Long tire irons also a major help. Heidenau tires by any chance ?? if so you have the toughest tire on the market for your first set!!
PD
Pay Dirt is offline   Reply With Quote
Old 07-14-2014, 05:46 AM   #7
pelvis_98
Havin A Time
pelvis_98's Avatar
Oddometer: 1,982
I also find if you are having a problem getting them mounted, walk away and take a break. You ended up just getting more frustrated with it. If you talk a break you end up coming back and more calm and working through it correctly.
pelvis_98 is offline   Reply With Quote
Old 07-14-2014, 06:37 AM   #8
IJM OP
IJM's Avatar
Oddometer: 223
Excellent Advice
You're right on - that's what I did walk away and let it soak up some sun.
Old 07-15-2014, 07:59 AM   #9
bwokentoof
Pollyanna Man
bwokentoof's Avatar
Oddometer: 346
Wicked oye...
I tried to mount a tire once resulting in a restraining order
I can get more done in a day than you can in an hour.
bwokentoof is online now   Reply With Quote
Old 07-15-2014, 11:29 AM   #10
IanInCalgary
Oddometer: 96
As indicated by others it is important to get the tire hot (leave in the sun for 1/2 hour or so), use lots of lube, and keep the bead in the drop centre of the rim (you may need to use some C-clamps to do this).
Another tip is to be sure to insert your tire iron the "right" way. If I'm working the bead on from the right (i.e. the tire is already on the rim on the right-hand side) I insert the tire iron from the left. If you insert the tire iron from the right you'll suffer. Inserting the tire iron from the left kinda moves the tire in two stages - the left-most portion of the tire contacting the iron moves the bead a little bit so it is part way on, and the actual spoon moves the bead fully onto the rim. Take small bites and you're good.
Ian
IanInCalgary is offline   Reply With Quote
Old 07-15-2014, 01:16 PM   #11
IJM OP
IJM's Avatar
Oddometer: 223
Good one, before I got the bugger in place I thought I'd end up mounting it all right, or it would end up mounting me.
Old 07-23-2014, 07:59 AM   #12
Oldrookie
Oldrookie's Avatar
Oddometer: 117
Thumb Mouth was empty, fortunately
ROFL
You couldn't make my grin any bigger without moving my ears
Oldrookie is offline   Reply With Quote
Old 07-25-2014, 09:17 PM   #13
statsman
Weekend Warrior
Oddometer: 87
If you are in the east end, try Flying Squirrel at 388 Carlaw between Gerrard and Dundas. Phone 416 889-8769.
Glen there does mounting and balancing. I don't know how much he will charge you if he didn't sell you the tire himself.
It is a parts only place, not a mechanical shop.
statsman is offline   Reply With Quote
Old 07-26-2014, 06:42 AM   #14
keener
Speed changes you.
keener's Avatar
Oddometer: 928
131 Wendell Ave
416-241-2523
+1
$20 mount, balance,....
04 ADV 950
keener is offline   Reply With Quote
Old 07-31-2014, 02:52 PM   #15
Sunday Rider
Adventurer Wanabe
Oddometer: 778
Thanks for the recommendation Statsman!
Just got my tires installed and balanced there. Glen is a fantastic guy. He did it using a No Mar machine(so lots of labour to get the rear tire on) and static balance. He charges $25 per wheel, off the bike. I already had the tires, I didn't buy them from there. He took excellent care during installation.
Would use again for sure.
'97 Honda ST1100
Times are GMT -7.   It's 09:14 AM.
