Old 07-18-2014, 10:51 PM   #1
Mudguts OP
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,137
Rally engine's & exhaust systems
Ok we have the Nav tower thread , the ICO thread so here's the engine thread
For tips and rebuild tricks
So my set up is this
KTM 690. (654cc) bone stock : well motor has not been molested as yet
Vortex X10 programable ignition
Andrea Dionda Rally exhaust 50mm through to 60mm at muffler link pipe
Muffler Akro rally. 60mm taper core down to 50 mm at exit
So my bike goes Ok but I also know that the exhaust is to big for my current set up . Im in planing of building a big bore engine in other words saving $$$$ for the parts
1) 2012 stroker crank
2) port & polish head
3) Cam stock ,Rally , DukeR ????
For the piston there are a few chooses
Stock 102mm 11.8:1 Compression Ratio
Hi Comp 102 12.5:1 CR
Then I can go 103 ,104,105mm piston , but may have to swap over to carb'd and $$$$.
I'm leaning towards stock size piston for ease of sourcing and reliability but also want a torque monster that can wheel stand at 100kph in 4th
Birth of a Rally Bike - KTM525
Mudguts is offline   Reply With Quote
Old 07-19-2014, 05:22 AM   #2
Mad Cow
Dakar Addict!
Mad Cow's Avatar
Oddometer: 659
I'm of the opposite opinion, go standard for maximum parts availability.
My 450 has an entirely standard engine.....
Including a "standard" 525 barrel and piston
NOMAD RACING
2015 Honda CB500X - 2011 KTM 990 Adventure - 2006 KTM 450 Rally
Mad Cow is offline   Reply With Quote
Old 07-20-2014, 05:01 AM   #3
michael1968
michael1968's Avatar
Oddometer: 885
Stick size piston is good because you don't need to worry about getting your barrel bored out and the potential issues associated with that (sleeves failing, cooling etc.).
You probably know but you don't want to polish your intake ports, the slightly rough surface keep your fuel from forming big drops.
Another good few hp out of a 690 and you'll have a real weapon!
michael1968 is offline   Reply With Quote
Old 07-20-2014, 04:08 PM   #4
Mudguts OP
Mudguts's Avatar
Oddometer: 2,137
Defiantly new more torque to lug my fat ass around , but had a win out playing with the fuel trims on Saturday
Old 07-22-2014, 06:22 PM   #5
Mudguts OP
Mudguts's Avatar
Oddometer: 2,137
Just had Crazy idea of a twin cam head for the 690 I think it would be a good way to throw away $$$$$$$$ .
Old 07-22-2014, 09:16 PM   #6
craigincali
Just hanging around
craigincali's Avatar
Oddometer: 2,174
if you want to spend cash I will give you my paypal account and you can put it in there.
Me
I am usually drunk when I post so dont take it personally !
2010 KTM 990
craigincali is offline   Reply With Quote
Old 07-24-2014, 10:32 AM   #7
JMo (& piglet)
Gone a bit Baja
JMo (& piglet)'s Avatar
Oddometer: 4,445
Rally Raid Products have just introduced a hi-comp piston for the stock bore... that would be a good place to start?
Jx
JMo (& piglet) is offline   Reply With Quote
Old 07-25-2014, 10:33 PM   #8
Mudguts OP
Mudguts's Avatar
Oddometer: 2,137
Jx
I'm keeping an eye on john's and martins FB web sites just in case they post some dyno runs with the new pistons
Old 07-25-2014, 10:55 PM   #9
JMo (& piglet)
Gone a bit Baja
Oddometer: 4,445
I'll mention it to them - I know that Martin has his own 'demo' 690 EVO2 set up now, so perhaps the new HC piston will find its way in there soon!
Jx
Old 07-29-2014, 02:35 PM   #10
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,814
Ditch the cams and go with solenoids
Seth S
Seth S is online now   Reply With Quote
Old 07-29-2014, 07:31 PM   #11
Mudguts OP
Mudguts's Avatar
Oddometer: 2,137
Trying to keep the electrical simple
Old 07-31-2014, 04:33 PM   #12
Seth S
Seth S's Avatar
Oddometer: 4,814
Well lets see..
My current engine is running stock rods with offset bushed flat top vw piston. The 16v head is fitted with double valve springs, rally cams, solid lifters, and bigger volvo valves. Alumiunum flywheel at the moment and likely a quartermaster clutch. Header is a 4 into 2 into 1 header. Custom ITB intake and T5 fuel injection. Possibly an electric water pump and more compact denso alternator.
Seth S
Old 08-01-2014, 12:29 AM   #13
Mudguts OP
Mudguts's Avatar
Oddometer: 2,137
And it's got four wheels Pppfft , traction junkie
Old 08-01-2014, 07:14 AM   #14
JayBo1
JayBo1's Avatar
Oddometer: 2,805
Originally Posted by Seth S View Post
Well lets see..
Yeah, but does it's wheels fit between the rails of a stock grate?
JayBo on Safari/Dakar
#101 Dakar 2015, Kiwi Safari Team, Perth, WA
KTM 450 Rally ... Dakar ready
KTM 530 EXC-R
Cagiva 750 Elefant - Lucky Explorer '88
JayBo1 is offline   Reply With Quote
Old 08-01-2014, 12:18 PM   #15
Seth S
Seth S's Avatar
Oddometer: 4,814
Not when it's airborne
Seth S
Times are GMT -7.   It's 10:42 AM.
