Old 07-21-2014, 09:16 AM   #1
hardtarge OP
Oddometer: 43
Nail and shredded front tube???
Going along highway speed and front bars start to shake bad. Drifted left over the center lane. Then convinced the bike back to the shoulder went through the ditch and into the corn field. . . .
why would the tire deflate so rapidly? Yes huge hole in the tube. . .
Poor tubes from the factory?
Damage? Tire tube. 2 bike lengths of corn. . . Loss of personal Mojo. . .
Lessons?? Need more tools and spare parts. I guess this is crap learned prior to 500 mile break in service.
hardtarge is offline   Reply With Quote
Old 07-21-2014, 09:24 AM   #2
SloMo228
World Class Cheapass
Oddometer: 1,722
That is one of the big drawbacks of tube-type tires. They're basically just thin balloons inside the tire, and like a balloon, when they get punctured, they tend to pop and lose all of their air in a very short time.
Losing pressure in the front tire at highway speeds is no joke, you did well to ride it out without crashing. Unfortunately, there's not really all that much you can do about punctures like you had there, it's very hard to see a nail in the road when you're riding along at 70+ MPH.
It's bad luck that you got a flat, but you had great luck in not coming off the bike and being badly hurt.
--------------------------- Steve----------------------------------------
'93 GL1500 frankenbike basketcase in progress
'96 DR350SE
SloMo228 is offline   Reply With Quote
Old 07-21-2014, 08:27 PM   #3
hardtarge OP
Oddometer: 43
Would a tubliss tube. Help in a situation like this??
Trip into the corn was first time off the pavement for me...
Old 07-21-2014, 09:10 PM   #4
DesertTortoise
Freedom Fighter
DesertTortoise's Avatar
Oddometer: 150
Tubliss isn't rated for road use if that matters to you. It has a bike tube at 100+psi which basically seals it and makes it like a tubeless tire + rim lock. You can still get a flat tho, it can just keep running on the flat without tearing the tire off. It's really made to run low psi off road that would destroy a normal tube.
Glad you kept it upright :)
DesertTortoise screwed with this post 07-21-2014 at 09:17 PM
DesertTortoise is online now   Reply With Quote
Old 07-21-2014, 11:44 PM   #5
folknride
Old Adventurer
folknride's Avatar
Oddometer: 667
RideOn
Well, sometimes I sound like a salesman for this stuff - RideOn - (I'm not), but I'm pretty sure this time it saved me some real unpleasantness. I use it in my tubes, and as you can tell from that nice worn down nail head, it took quite a while for this tire to deflate. Pretty sure I picked it up in a a rancher's yard where we stayed, and rode 30 or so miles of twisty pave and gravel before it gently went flat.
I'm a fan
(buy the kind that says "for tubes" on it)
But I'm glad you didn't crash - that would scare the crap out of me!
folknride is offline   Reply With Quote
Old 07-22-2014, 04:13 AM   #6
JohnCW
Oddometer: 1,259
With tubed tires I always carry a can of this stuff on the bike. Haven't had to use it yet, but used a similar product a number of years ago and it worked well enough to get me home. I'll work as long as the tube hasn't completely ruptured. Just be prepared to spent the next 3 weeks scraping the latex of your wheel and bike as it goes everywhere as you ride along till it sets up.
JohnCW is offline   Reply With Quote
Old 07-22-2014, 07:52 PM   #7
just jeff
Oddometer: 868
Regarding sudden tube failures due to nails....The synthetic rubber tubes commonly available today tend to run/split when punctured and don't take to patching well. I look for and use natural rubber tubes which don't display these bad traits. As far as the Tubliss system....Still no 17" size available to fit the rear of the KLR. I believe a nail through the tire could puncture the Tubliss inner tube causing a sudden loss of pressure as well. My last flat on a gravel road at 60mph. No controll issues other than a slight squirrley feeling. Rode it home slow to save the tire. Tube had the valve stem torn out after going flat. One inch tear in tube at site of screw. Think Tubliss would have survived here? OR a Tubeless tire? 3/4 hr later and a new tube it was going again.
Screw in through the tread and out the sidewall of a MOTOZ Tractionator on my KTM690
ErikMotoMan: "People struggle with many things in their lives. But the answer to struggle isn’t MORE struggle. It’s peace. If you want more joy, peace, love, happiness… you have to GIVE those things first. You have to THINK those things. You have to have faith that they’ll come to you, despite what you may see. The truth isn’t in what you see with your eyes. It’s what you feel in your heart."
just jeff is offline   Reply With Quote
Old 07-22-2014, 08:42 PM   #8
DesertTortoise
Freedom Fighter
Oddometer: 150
The Tubliss inner tube probably would have survived that one... You'd still have a hole in the sidewall and need a new tire tho instead of a new tube
Old 07-23-2014, 04:27 AM   #9
foxtrapper
Oddometer: 755
Cheap tubes tend to rupture when punctured. Quality tubes, which are quite a bit more expensive, simply puncture. The differences I see between them are the cheaper tubes are thinner walled, more plasticy vs rubbery, and tend to be smaller and therefore further stretched upon inflation. I see this in everything from bicycles to farm equipment and motorcycles. Cheap tube look like they've shattered when punctured, expensive quality tubes have a repairable hole.
foxtrapper is offline   Reply With Quote
Old 07-23-2014, 07:14 AM   #10
markk53
jack of all trades...
markk53's Avatar
Oddometer: 8,379
Here's a thought based on what I saw once at a bike shop where I worked...
The mechanic (not a technician, a real mechanic ) was putting a tire on the front wheel of a CB500. Broke the tire down... no tube!
Someone had wrapped the rim with duct tape and put in a tubeless tire valve and mounted a tubeless tire (most are tubeless now, thank the GS and other tubeless adventure bikes). The damn thing actually sealed up!
Now I'm not saying to do this, but the thought is to run a tubeless type tire, which has an air tight membrane inside that make it air tight, and duct tape the rim in place of the rim strip before mounting the tire. Most rims now have a good bead seat like most tubeless rim profiles. Now odds are the only place air can escape is the valve area and whatever hole is in the tire.
That would stop any rapid leakage at any spoke holes. Maybe gives more time to get off the road when there is a puncture.
No guarantees, but if it works, it's worth it.
Don't be concerned running a tube in a tubeless tire. It's common practice and most manufacturers will tell you it reduces the speed rating by one level. Not many will be running around at triple digits for miles at a time on roads.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens!
Mark - klx678
95 KLX650C w/Vulcan piston bigbore, Now an 09 KLX250S, selling my 90 Zephyr 550
markk53 is offline   Reply With Quote
Old 07-23-2014, 02:58 PM   #11
scottrnelson
Team Orange
scottrnelson's Avatar
Oddometer: 1,435
And if it doesn't work, you've only wasted a few hours.
Most tube-type rims that I've dealt with aren't designed to hold the bead tightly in place to get the seal that you need for a tubeless tire. I would be surprised if any of them held air for very long, assuming no air leaked out through the spokes.
Old 07-23-2014, 08:03 PM   #12
hardtarge OP
Oddometer: 43
Well changed the tube I was surprised.
Hole is about 1/8 in ? Maybe twice the size of the nail Name:  uploadfromtaptalk1406167299251.jpg
My personal mojo maybe restored ride on or slime may have helped?
Old 07-23-2014, 08:15 PM   #13
T
stay classy
T's Avatar
Oddometer: 5,266
I've sealed spokes on rims before and I'm a believer in this. And use a rubber washer at the valve hole.
Inconsequential Adventurer
T is offline   Reply With Quote
Old 07-23-2014, 09:09 PM   #14
BeMeUp
neverlost
BeMeUp's Avatar
Oddometer: 82
Wicked Balls
Two words "Tire Balls" jusGOOGLEit. You can run with a hand full of nails in your tire. They're pricey but most front wheel flats at highway speeds don't end cheaply......... as did this one Glad you you only plowed a bit of corn.
Lost is relatively geographic!
BeMeUp is offline   Reply With Quote
Old 07-24-2014, 08:41 AM   #15
markk53
markk53's Avatar
Oddometer: 8,379
Just how long does it take you to run a couple of passes of duct tape around the inside of a rim?
It was common practice years ago. Oddly enough, Motion Pro makes rim strip tape. Some enduro and other sites still point out the tape works in place of a rim strip and odds are it won't break on the trail if a flat has to be fixed. I guess it's a personal choice.
As far as the tire/rim holding air - Like I said, hard as it was to believe, I saw that CB500 front rim and it was holding air when it came in. Obviously it went out with a tube in there.
I make no recommendations to run without a tube, just mentioning that the tape will seal the spoke holes up for sure. Less places for air to leak. It may be worth doing just for the chance that it will help.
Mark - klx678
Times are GMT -7.   It's 09:11 AM.
