View Results: Rate the White Rim Trail for Difficulty.
1 5 14.29%
2 12 34.29%
3 13 37.14%
4 3 8.57%
5 1 2.86%
6 1 2.86%
Voters: 35. You may not vote on this poll
Old 07-22-2014, 08:59 PM   #1
hayduke.klr07 OP
hayduke.klr07's Avatar
Oddometer: 162
Have you ridden The White Rim Trail Moab?
If you have been to Moab and have ridden The White Rim Trail on a 650 or larger, tell me how hard you think it is. Think about the whole ride, not just the hardest or easiest parts. This rating would be in relation to anything else you have ridden anywhere on your 650+.
On a scale of one to six, one being a straight forward gravel road and six being the gnarliest thing you think you could ride on your 650+ tell me your rating by participating in this poll.
hayduke.klr07 is offline   Reply With Quote
Old 07-22-2014, 09:22 PM   #2
rob1313
Still learning
rob1313's Avatar
Oddometer: 4,378
Rode it on a stock 08 KLR 650 with stock tires. Not all that hard at all. Beautiful and worthwhile.
"To live is the rarest thing in the world. Most people exist, that is all." - Oscar Wilde
rob1313 is offline   Reply With Quote
Old 07-22-2014, 09:54 PM   #3
rgiroux
Invisible Man
rgiroux's Avatar
Oddometer: 2,357
3 of us on GS's and one on a 950 KTM
about 10 hrs to do it all. all fun!
"Otherwise, its been a carnival of idiots, and Im the f*ckin ringmaster" - RTW Doug
Speed is your friend, it also why you see a bike up in a tree from time to time - WarLlama
2009 Alaska , 2010 Moab
2011 Calif Dreaming , 2013 Mexico
rgiroux screwed with this post 07-22-2014 at 10:00 PM
rgiroux is offline   Reply With Quote
Old 07-22-2014, 10:06 PM   #4
kennyh
kennyh's Avatar
Oddometer: 291
what a great ride it is. I've done it a couple times, once on a loaded super enduro and once on a 450. Not particularly technical IF the weather doesn't turn sour. I imagine the dirt would pack up on you if it was muddy. Sand in some spots that can be tricky if it is too dry. Take plenty of water and be prepared for it to take longer than you think due to photo ops and such.
Started around on one of the trips at about 3pm. Wasn't the smartest move as about 3 hours of it was after dark. Made the trail hard to follow but what a sky!
from last year.
Smugmug referral code : 01cndVMii0Dl2
kennyh is offline   Reply With Quote
Old 07-22-2014, 11:36 PM   #5
Sparrowhawk
Sparrowhawk's Avatar
Oddometer: 2,177
A buddy and I did it this June. I was riding an old 640 LC4 and my buddy on a 690 LC4. Maybe a 2.5 on your scale. There are a few rocky climbs and a short stream crossing when we rode it. Beautiful country. Bring lots of water because it's hot and there's not much shade. Well worth the trip. Air down but not too much because the rocks are sharp.
If you get down south as far as Bluff, be sure and stop by Comb Ridge Coffee. Best espresso in Utah and the blue corn pancakes are great any time of day.
Sparrowhawk is offline   Reply With Quote
Old 07-23-2014, 11:06 AM   #6
Goss
LC8 Adventurer
Goss's Avatar
Oddometer: 1,377
The only difficult thing about the WRT on a bigger bike is the sand. Learn to navigate that with some confidence and it will be enjoyable.
My ride was my KTM 950S.
2004 KTM 950 Adventure S
2007 Ducati 999S Parts Unlimited
2012 Ducati Multistrada 1200 Pikes Peak
Goss is offline   Reply With Quote
Old 07-24-2014, 08:41 AM   #7
OrangeYZ
Oddometer: 578
I did it on a 525, and I would rate it a 1.
If I had been on the KLR I would still rate it a 1, but I would go a little bit slower to avoid breaking my wheels on things.
Originally Posted by kennyh View Post
from last year.
You didn't break the speed limit, did you?
OrangeYZ is offline   Reply With Quote
Old 07-24-2014, 12:44 PM   #8
Rodzilla
Horny as Hell
Rodzilla's Avatar
Oddometer: 1,543
This is key.
It is also a difficult one to answer. I've ridden Moab and the greater Moab area for 20+ years now, usually 2-3 times each Spring and Fall (and even a one day trip from Denver in the winter, 12 hours driving, 5 hours riding) Although my ride of choice is my KTM 453 as opposed to the big bike.
The thing about the area and whether you'll find the trail easy or hard has a lot to do with your experience level and your confidence with the following:
1. Sand: There is quite a bit of it, and even people that have ridden for years and are very confident otherwise can have issues if you don't have sand riding experience.
2. Momentum: This is uber important in the Moab area. While less of a problem on WR, much of the area has a lot of sand/rock/sand transitions and a lot of ledges. 95% of the time a little "mo" will carry you right up/over most of the challenges of the region, even on a big bike. But so many riders never have the experience of this type of terrain, and there can be a mental hurdle to get over. See minute 2:11 in the video above. From experience, trusting your equipment and rolling down spots like that is key, but it's easier said than done when your brain is saying "NO!" (and when your riding a $15k bike :)
3. Heat/stamina: I don't consider WR to be a difficult trail, it is as much about WHERE you are riding as opposed to what you are riding. But in Moab, it is so dry and can be so hot, people coming from lower elevations with more humidity, it can really take it's toll. Riding 100+ miles along a trail with sand/rocks etc.... in 85+ degree heat with 15% humidity can up the challenge.
COHVCO/COTPA/BRC/USA-ALL/ARRA/AMA/Moab Parnership
COHVCO Supporter
Rampart Range Motorcycle Management Committee(RRMMC) Past President/VP
Certified SAE J1287 sound tester
Rodzilla screwed with this post 07-24-2014 at 01:35 PM
Rodzilla is offline   Reply With Quote
Old 07-24-2014, 02:37 PM   #9
DADODIRT
DADODIRT's Avatar
Oddometer: 3,472
Guess I can't vote, but here's my $0.02 as I have ridden it on my KLX300. Wish I had a bigger bike. 650 would be perfect. Mostly for the length, but also lots of easy stretches between the few difficult ones. My KTM 950 would probably make it a 4, but I haven't done that yet.
I find your lack of faith in the force disturbing.
DADODIRT is online now   Reply With Quote
Old 07-25-2014, 09:36 AM   #10
farmerstu
Oddometer: 459
did you understand the op question?
or are you being a smart ass and insinuating that you are such a great rider that anything less then straight up mt. Everest is just too easy for you?
I have not been there , but a couple of stream crossing and lots of sand certainly ranks it more difficult that a good gravel road. as does having to avoid things that could break a wheel.
OP asked a serious question,from people who have been there. He deserves a honest answer.
farmerstu is offline   Reply With Quote
Old 07-25-2014, 09:46 AM   #11
Skidmarkart
Dirty Middle Age Man
Skidmarkart's Avatar
Oddometer: 209
It's not bad, I drove it in April, and was surprised by how good the condition of the road was. Admittedly it was early in the season, but I did pretty much wish I was on my DR650 pretty much the entire time.
That said, there are some deep sand sections in the washes that would not be too fun (at least for someone if my experience), and some rocky "scrambles" ( I say scrambles only because I ride on pavement 95% of the time) but it is really not bad at all. Even with my fairly limited off road experience, I felt like I could ride the trail without fear (and hope to do so, sometime in the not too distant future).
Enjoy the ride, it really is an incredible place.
Skidmarkart is offline   Reply With Quote
Old 07-25-2014, 10:38 AM   #12
OrangeYZ
Oddometer: 578
I kind of want to now.
I forgot about the sand. I still forget about stream crossings, but if someone says it's there, it's there.
I'll add that on an 800XC with dirt tires I would call it a 2, and a 3 with the stock tires. And if it was raining hard I would probably turn around and go home no matter what I was riding.
"Not just the easiest or hardest parts"
Of the 110 or so miles, most of it is smooth, two track dirt road. The hardest part I remember is the climb up and down Hogback hill, and when I got to the top there were pick ups and cars carrying gear for a troop of boy scouts on a bicycle ride.
The scenery was memorable. The difficulty was not. This is my opinion.
Old 07-25-2014, 12:03 PM   #13
farmerstu
Oddometer: 459
o.k.
but i consider a good gravel road. ( a 1 in the op scale) easily passable with any motorcycle without any special tires or equipment. be it a full dress harley or goldwing or stock KLR.
Old 07-25-2014, 12:33 PM   #14
KustomizingKid
Oddometer: 678
It was very easy... Did it in 3.5 hours on an Xr650r by myself. There are a few climbs and tight turns. That said I did it right after spending a month in Mexico... And in the Sierra Madres or Baja it would be called the White Rim Road and a guy would be driving a fully loaded semi down it.
2000 Xr650r!
KustomizingKid is offline   Reply With Quote
Old 07-25-2014, 02:06 PM   #15
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,698
4.
I've riden it twice, once with a F800GS and once on a CRF250X. The sand was challenging on the F8, and I was glad I did it clockwise. The rocks get to be annoying on the big bike. On the whole it was okay and very doable. Take water with you. The next day we packed up and road over to Zion, so having the bigger bike was nice.
The 250 wasn't very comfortable for that long of a ride.
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is online now   Reply With Quote
Times are GMT -7.   It's 01:08 PM.
