the DR650 thread
Discussion in 'Thumpers' started by sleepywombat, May 2, 2006.
  1. William Wolfen
    William Wolfen Long timer
    Dec 5, 2015
    6,761
    Cypress, TX
    Regarding the mouse problem, real seem to br missing the proper solution... get a cat or 2. Even if the cats don't catch the mice, they'll know the cats are about and stay away. I've never been without cats and have never had a mouse problem.
    Higher Logic, procycle and Nobade like this.
  2. ADV8
    ADV8 Long timer
    Nov 11, 2007
    2,780
    North of Sydney.
    Mainly for all the parts matching (RMZ) and the bigger 20 mm axle plus I have had that RMZ front wheel and axle for a long time now.
    I could machine a new hub (To take the heavier gauge Buchanan DR spokes with bigger OD bearings) but have way to many projects now.
    I will take a closer look once I get this mess in order. :lol3
  3. Rusty Rocket
    Rusty Rocket Life behind "Bars"
    Dec 22, 2005
    21,035
    Tri- Cities TN
    could this be done to the inside of a fuel tank?
    Fishnbiker likes this.
  4. TwoUpTourer
    TwoUpTourer Long timer
    Jan 11, 2010
    2,309
    South Australia
    Yes. But you would have to carefully set up the rods so that nothing touched the +positive rods. I would make a custom plug so that a pair of rods would splay out either side, and make sure it can breath. Remember that the negative attaches to the part you are removing rust from, so in this case it will be the +positive connected to those two internal rods, which must not touch the tank internally, and the negative to the tank itself, like onto the mounting bolt holes for example.
    I've had amazing success with electrolysis using a battery charger and washing soda, in hours removing the rust from century old horse shoes and anything else I've wanted cleaned up. Learnt it on Youtube - who'd a thunk it???
  5. Rusty Rocket
    Dec 22, 2005
    21,035
    Tri- Cities TN
    cool idea. I have a generator that was given to me and the tank is horribly rusted inside. The price of a new tank is more half the price of the same generator when it's on sale
  6. Tall Man
    Tall Man v2.0, at your service.
    Jul 14, 2007
    11,946
    The Occident
    Agreed. And get female felines, if you're able. They're better mousers. Voice of experience here.
    TreasureState likes this.
  7. BergDonk
    BergDonk Old Enough to Know Better
    Nov 15, 2010
    24,945
    Snowy Mountains Oz
    Brake cleaner on a rag does the same.
    +1 for SSB, I have 4 in current use without issue, except for the occasional really cold, below 0 C, am start when they need some warming.
    Maybe a leaner oil mix too, 20:1 will leave a lot of smoke behind.
  8. BergDonk
    Nov 15, 2010
    24,945
    Snowy Mountains Oz
    On the jump starter thing, I recommend everyone fit a permanent Anderson plug to their bike.
    I carry a short Anderson plugged jumper lead, along with an alligator clip tail in case the other battery doesn't have an Anderson connection.
    I''ve usually got a hill around here for bump starting, but outback, on the flat and in some sand, its not so simple.
  9. Sonny S.
    Sonny S. Long timer
    Nov 23, 2015
    7,616
    Over here
    you can also fill the tank with 50/50 water and white vinegar. depending on the rust...6-12 hours
    wee-twin, Hivernaut, JagLite and 2 others like this.
  10. BergDonk
    Nov 15, 2010
    24,945
    Snowy Mountains Oz
    One of these sacrificial plates can alleviate the gouged swingarm thing.
  11. AlH
    AlH Long timer
    May 8, 2015
    4,074
    SC/NC
    Puzzled by the statement that it fits all 50A Anderson type connectors.
    I use those a lot- on my camper, on my van, on battery chargers, the really big 350A ones on vehicle winches, etc
    BUT-I found out the hard way that the different color Anderson's don't plug into each other- I usually buy grey but ran across some red ones at a good price-ordered some and they won't plug into the grey! Keyed differently.
    A few minutes with a dremel and a burr fixed that but caveat emptor.
    Hopefully they made those without the keyed center part.
    Hivernaut likes this.
  12. BergDonk
    Nov 15, 2010
    24,945
    Snowy Mountains Oz
    Ones I've setup so far have been fine. Maybe there is an Anderson licencing/IP thing that other manufacturers have to deal with?
  13. cyberdos
    cyberdos Easy Bonus Loop ♦♦
    Sep 2, 2005
    49,239
    Queen Creek, AZ
    Whatcha got going on there in the green?
    :lurk
  14. ADV8
    ADV8 Long timer
    Nov 11, 2007
    2,780
    North of Sydney.
    You tell me now. :lol3
    After the gouge coming back from the Cape I just grabbed the stand leg and pulled (bent) it away from the swing arm but it was a bit late by then.
    biker128pedal likes this.
  15. ADV8
    ADV8 Long timer
    Nov 11, 2007
    2,780
    North of Sydney.
    The bike ?
    A 1954 Sunbeam S7 Deluxe, I have a 1949 also which is getting a full mechanical but no cosmetic.
    I have a AMR300 supercharger that I would like to fit to the 49 but not sure if that is a good idea or not, 25 HP standard but that could bump it to stock DR HP (34hp)
    Then again with it bolted to the DR780 ????
  16. BergDonk
    Nov 15, 2010
    24,945
    Snowy Mountains Oz
    That's the issue. I parked my DR at a mate's place and it was a bit soft and I did an awkward dismount and bike went over along with me. Stationary, and would have been a laugh, I even nearly laughed myself. Before I moved off I checked the stand, and sure enough, it'd bent in, the only damage, along with my pride, not that I have much left! So I tweaked it there and then. Most of the time, if people have an off, they don't check the sidestand swingarm clearance and then, like you observed, its too late. A bit of stainless sheet is perfect, but steel or aluminium is better than nothing.
    Looks like @JNS Engineering will be making them real soon, maybe :hide
    Others have glued rubber or something else there, or a couple of nutserts and a plate would work too, but this design is the easiest to implement, and its robust enough. The pic was originally posted here; https://advrider.com/f/threads/a-dr650se-for-africa-built-in-switzerland.1203292/
  17. spklbuk
    spklbuk Long timer
    Dec 8, 2007
    2,070
    SE Almost Heaven
    Clean, clean. Clean to the ol' rokejortel...
  18. Higher Logic
    Higher Logic Rural Lone Wolf
    May 1, 2011
    15,136
    Bug Tussle Ranch
    Yes, that's what it is for.
  19. EastBoundAndDown
    EastBoundAndDown Ron - 300XCW DR650 990SMT
    Aug 22, 2010
    3,392
    Outskirts of Gwinnett, GA
    A bit of loose rock might work first to shake the heavy stuff free yeah?
  20. Lil' Steve
    Lil' Steve Every day is Saturday
    Oct 3, 2006
    6,382
    Gilbert, AZ
    Since it's in the name of science (and the promise of beer) I've volunteered to donate a cylinder head to the cause. Stay tuned, folks. :lurk
